20 Most Recent Maytag MGC6430 Gas Cooktop Questions & Answers
Depends on model-call maker and ask if there is a glass replacement for stove top.
Maytag MGC6430... | Answered on Aug 24, 2012
The manifold valves can be purchased separately.
Part numbers are;
74004634
74004635
Maytag MGC6430... | Answered on Apr 25, 2010
Your gas inlet valves are turned up to high or there is air in your system. Most of the time the burners are set either to high or to low. Meaning that not enough or to much gas pressure is being forced through the system.
Maytag MGC6430... | Answered on Jan 01, 2010
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Maytag MGC6430... | Answered on Dec 05, 2009
Use this link for answers to all your cooktop issues.
Maytag Cooktops | Answered on Mar 15, 2019
Go to your electrical panel and check the circuit breakers. If one is tripped it will be in a halfway position. switch off then on. If it keeps tripping you may have to call a repair man.
Maytag Cooktops | Answered on Feb 10, 2019
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Maytag Cooktops | Answered on Jun 19, 2017
Sure. The wiring harness can be repaired or replaced as well as any damaged components.
Maytag Cooktops | Answered on Aug 29, 2016
replace that element
Maytag Cooktops | Answered on Feb 19, 2015
something got spilled on it . see if top lifts up and wipe all moisture out if you can
Maytag MGC6430 Gas Cooktop Logo
7 questions posted
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Marvin
Marvin
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Maytag Cooktops
  • Maytag Cooktops
Most Popular Question
one control knob maytag mgc 5430 will
  • Cooktops
