20 Most Recent
Maytag MGC5536 Gas Cooktop Questions & Answers
All of the burners on my range started flikering
yikes .. you have a very dangerous condition there ... ventalate the area and turn the gas off immediatly.. there is a shutoff valve somewhere in the gas line coming to the stove top .. if you cant find that then shut off the gas at the gas meter or call the gas company to do that for you (its free) ...
your problem is likely a loose pipe or cracked manafold .. it is leaking gas under the cooktop .. i would replumb the unit and check for cracks .. or call a professional .. your unit comes with a 1 year warranty or an additional 4 years if you bought extra coverage .. that probably wont cover a bad installation if thats the problem (unless the repair company installed the unit to start with) .. but will cover the stoves inside plumbing ..
your stove is not safe the way it is .. if you can still smell gas then you shouldnt be in the house until the gas is turned off ... windows should be open .. dont turn on lights or other things that can ignite the gas .. and absolutely dont try to relight the burners until the problem is fixed ..
Ignition keeps on flickering
clean the bottom of the knob by using vacium,remove the knob,pii it hten clean the area of the gas valve wen the knob possition,then return the konb
tnx gerbee
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
