20 Most Recent
Maytag MGR6772BDS Gemini Gas Kitchen Range Questions & Answers
The bottom oven makes a big 'boom' noise
every right to be concerned
you have a gas leak that will explode doing a lot of damage
as gas in not the DIY domain , call an accredited gas fitter to fix the problem
in the meantime do not use the stove until it is fixed
6/22/2017 10:14:55 AM •
Maytag...
Answered
on Jun 22, 2017
Has anyone else had a serious problem with the
Same problem here - and I have read about others with this problem. Usually blamed on moisture getting into the control unit ( which is under the backmost burner knob). I did not have a spill on the cooktop, nor was I "over zealous" cleaning. Looks like a bad design. Waiting to hear from the technician how much THIS is going to cost me...
3/21/2016 11:55:17 PM •
Maytag...
Answered
on Mar 21, 2016
Upper oven will not heat up, broiler does not work.
Hi Larry
Use a multimeter on AC range to test for voltage on wires going to bad element.
It's probably a bad switch or open element.
Elements often unplug for replacement. Don't always show damage of burned out conductor. So... Use your multimeter on the ohms scale to test for continuity at each end.
Upper oven element is likely open circuit and will need to be replaced.
Cheers
11/3/2015 1:34:52 PM •
Maytag...
Answered
on Nov 03, 2015
Top oven doesnt work
This is simply a bad bake element and one of the most simple repairs you can make. When you purchase your parts through us, we provide part removal/installation instructions for you!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
for all your appliance repairs, parts & accessories supplies. We love our job and love helping out with any type of appliance request that you have.
We hope to hear from you soon and we'd love to get you cooking again, so call on us when you need us. Thanks! Ella
12/3/2014 10:15:12 PM •
Maytag...
Answered
on Dec 03, 2014
5A6 6ATH error message
Hi and Wlecome to FixYa, I am Kelly.
This is the Sabbath mode. Why it even exists is odd in itself.
Hold CLOCK for 3 seconds to disable the Sabbath mode.
This should get it back to normal operation.
Thanks for choosing FixYa,
Kelly
3/11/2014 3:56:11 AM •
Maytag...
Answered
on Mar 11, 2014
I have a Maytag Gemini Precision touch 750 series
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
12/30/2013 3:17:42 PM •
Maytag...
Answered
on Dec 30, 2013
