20 Most Recent
Logitech Harmony 880 Universal Remote Control Questions & Answers
I have a Logitech Harmony Remote 880. The
First, you may want to try this
updated driver from logitech that seems to be built for WIn 7.
If this is somehow incompatible there are other options:
Have you tried installing with
XP compatibility mode?
You may also want to give
this driver a try as it is a couple of versions above the one you listed and may have bugs worked out for Win 7 installation. Hit the download button and wait a few seconds when the other screen loads. Don't download their PC Optimizer thingy lol.
Hope the links help and give me a shout if you need more help :)
Changes to fios and have motorola 7100 program my
If you have changed your hardware setup, you must reprogram your Harmony 880 using the Logitech software. You should be able to simply step through the 'interview-like' process and enter the new make and model number of the new hardware. It is usually recommended to add the new device first and then associate the new device with your existing Activities. Once your Activities have been mapped to use the new device, you can delete the old one. Once everything has been completed in the software, update your remote through the USB connection. Hope this helped!
I am trying to set up the
I have seen channel designations like this when using a satellite TV provider. From what I know (which is not a lot, I'm afraid) is that some affiliates offer analog and digital and digital sub channels so an example would be:
05 (main analog channel)
05-1 'digital' (depending on the receiver)
05-2 'digital sub channel'
05-3 'digital sub channel'
etc
So, you may want to try just putting in the main channel '05' when using the Logitech software to program your favorites. Below is a link to a good post on the Logitech forum that tells how to program your favorites. Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9691
Harmony 880 will not recharge anymore
Try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact.
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. Also, if it is still under warranty, I woul advise contacting Logitech's wonderful support team to get replaced.
Hope that helps!
I have a harmony 880 remote. Won't charge now.
Generally there are three possibilities (apart from the battery going bad) that can cause your remote not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). Opening the remote and checking to make sure that the plug is completely seated is another thing to check if all else fails.
880 universal remote volume button broke. little
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Harmony 880 Logitech won't change channels
Was it working before? Is it possible you selected the wrong brand of TV when programming the remote? Do you use a cable box or satellite dish with your TV (in other words, do you change channels by changing the channel on the TV, or on the digital box connected to your TV)?
How do I get my wireless Logitech PS2 controller to connect to the receiver
Observe these instructions to connect your wireless Logitech PS2 controller to the receiver :-
- Verify that the PlayStation 2 console is connected to the receiver.
- Switch on the PlayStation 2.
- Replace the controller's batteries.
- For roughly 2 seconds, press and hold the receiver's sync button.
- Press and hold the controller's X button for 5 seconds.
- To verify a connection to the receiver, the controller LED should flash rapidly.
Try the following if the controller won't connect :-
- Double-check the placement of the batteries.
- Experiment with various batteries.
- Bring the controller up to eye level with the receiver. Try rebooting your PlayStation 2.
Try getting help from Logitech customer service if you're still having issues attaching the controller .
Here are some extra pointers :-
- Verify that no other controller is currently using the receiver.
- Verify that no other wireless devices are present that could interfere with the connection.
- You might need to utilise an adaptor to connect the receiver if you're using a PS2 Slim.
8/21/2023 5:11:27 PM •
Logitech...
Answered
on Aug 21, 2023
Need logitech z340 control pod or compatible controller even if not logitech brand
The Logitech Z-340 control pod or a compatible controller can be found in a few different places. Here are a few options:
- Logitech website: You can check the Logitech website to see if they still carry the control pod or compatible controller for the Z-340.
- Online retailers: You can check online retailers such as Amazon, eBay, and Best Buy to see if they have the control pod or compatible controller in stock.
- Specialized Electronic retailers: Some specialized electronic retailers like B&H, Newegg, and Fry's may have the control pod or compatible controller.
- Local electronics stores: You can check local electronics stores in your area to see if they have the control pod or compatible controller in stock.
- Second-hand marketplaces: You can also try checking second-hand marketplaces like Craigslist, Facebook Marketplace, and OfferUp to see if someone is selling a used control pod or compatible controller.
It's important to note that, if you decide to go for a non-Logitech controller, you should make sure it's compatible with your Logitech Z-340. And it's best to check the compatibility before buying the controller.
1/23/2023 10:25:33 AM •
Logitech...
Answered
on Jan 23, 2023
Have a logitech 610 remote stuck in safe mode. Tried holding #2 and changing batties with new batteries but still stuck in safe mode
I'm sorry to hear that your Logitech 610 remote is stuck in safe mode. Here are a few steps you can try to try to resolve the issue:
1. Make sure you are using new, high-quality batteries.
2. Try resetting the remote by removing the batteries, pressing all of the buttons, and then reinserting the batteries.
3. If the issue persists, try connecting the remote to the Logitech Harmony software on your computer using the supplied USB cable. This will allow you to access more advanced troubleshooting options.
I hope this helps! Let me know if you have any other questions or if there is anything else I can do to assist you.
1/2/2023 9:12:04 PM •
Logitech...
Answered
on Jan 02, 2023
