20 Most Recent
Intel D945GCZ Motherboard Questions & Answers
I have lost my cd.
Go
here for latest chipset driver.
Go
here for latest LAN driver for XP.
Go
here for latest LAN driver for Vista.
Go
here for latest RAID driver.
Go
here for latest Onboard graphics driver.
All these downloads are directly from the Intel web site.
Please rate me high if you found this helpful.
Thanks.
Pci device driver
Support center for the motherboardJust select the correct O/S and follow the links
Trying to find heatsink unit to be able to use the
Hello here is the intel homepage:https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCZYour mainboard is using the LGA 775 socket.The heatsink fan looks like this:
The fan can still be bought in a computer store, online shop or a repair shop.I will recommend to but a better fan, like the brand
northq, because the standard fan is difficult to mount correctly on the mainboard.Remember to add a bit of
cooling paste on the cpu, before you mount the fan.Good luck
945 sound driver stup errer
Chances are your using realtek IC, check on *********** board for a computer chip that has a crab like logo on it, if you find one go to www.realtek.com and download everything that's there you should find a driver if that's the case. Now, I say download everything because there are both device drivers and audio codecs for the devices. If you do not have a realtek device you can try and look over your motherboard and identify what audio IC is on your motherboard and download the drivers for that model IC
I want to install audio
Check on Intel Web, Following this link :
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d945gcz
How to solve CMOS checksum and timer errors?
Your backup battery is to weak to save the cmos data. Open your computer case and look for a round silver battery that looks like a quarter. Remove it and go to Radio Shack or a drug store battery section and get a replacement. The battery number is probably CR2032 but may be CR2025 or CR2016. insert the new battery and power up your computer, this time when you set the time and date the settings will stay when you turn it off.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
My realteck driver (sound driver) is not working p...
visit http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCZ and update the driver.
When i installed windows 7 my sound system didnot
Did you check that the mobo was Win 7 compatible. There is a compatibility checker available on the Microsoft website. Windows 7 requires "Signed Drivers" for devices. From what I can gather on the driver download site the mobo is not really ready for Windows 7. Try a seperate sound card if you don't want to change boards. But check for Win 7 compatibility first.
I have upgraded my bios
Clean the fans. when a fan is rotating it impacts on dust particles at high speed this causes build up and an imballance which causes airflow disruption (noise). As long as you can get sound out of it I don't see the problem, Most stand alone cards give a better sound quality than inbuilt audio chips anyway. Also, they give more control over the sound output.
Motherboard945 sound driver download
Visit this site and download the required driver.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCZ
