20 Most Recent
Canon Eos Digital Rebel Ds6041 6.3 Mp W/50mm Lens, Battery & Charger Questions & Answers
The camera say,s , err 02
Err 02
Description: The camera cannot access the memory card.
Resolution:
- Remove and re-install the memory card.
- Format the memory card as described in the user manual. The user manual for your EOS camera can be downloaded form the Canon Europe EOS camera support page.
- If formatting the memory card does not resolve the error please replace the memory card.
9/2/2016 10:31:32 PM •
Canon Eos...
Answered
on Sep 02, 2016
Cannon rebel DS6041 shutter problem
You need to determine what is preventing the shutter from opening/closing. Set to "B" mode and with the lens OFF, press shutter button but DO NOT RELEASE just yet. Not any peculiar motions (grabbing, skipping, folding etc). The curtain may well be out of alignment, or there may be a lose part which is grabbing hold of another component.If you do find the culprit, and it can be fixed on the spot - do it. Technicians can charge >$65 just to open the thing. Then you have to wait at least a week to get it BACK!
11/26/2013 2:08:57 AM •
Canon Eos...
Answered
on Nov 26, 2013
Battery door latch broken
look for a Canon eos 300D battery door (they are the same camera just came out in different countries) or buy of ebay a cheap broken 300D and salvage the parts that way.
6/20/2013 10:23:37 AM •
Canon Eos...
Answered
on Jun 20, 2013
Driver fo Canon DS6041
More times than not all drivers can be found on the Canon site. If it is an older model then it may be in an other section for past models. You may need to dig a bit deeper to find it.
10/2/2012 2:18:11 PM •
Canon Eos...
Answered
on Oct 02, 2012
How to get software that downloads data from a canon digital camera
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
8/29/2012 3:07:52 PM •
Canon Eos...
Answered
on Aug 29, 2012
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
