20 Most Recent Konica Minolta Minolta Dynax 404 Si 35 Mm Film Camera Film Camera Questions & Answers
Can i use tamron 90-300 mm af macro on my minolta
Tamron makes lenses with a variety of lens mounts. If the lens has a Minolta mount then yes, you may use it with your camera.
1/15/2014 6:37:38 PM • Konica Minolta... • Answered on Jan 15, 2014
How to change the time & date Backup Battery on a Konica Minolta Dimage Z2
The backup cell is rechargeable and when the main battery is reinserted and charged, it will charge the backup cell after a while.
3/4/2024 4:41:35 PM • Konica Minolta... • Answered on Mar 04, 2024
Konica Minolta Dimage Z6 working fine, but Windows 11 wont recognise it. Any ideas please?
If your Konica Minolta Dimage Z6 camera is working fine but is not being recognized by Windows 11, there are a few things you can try to troubleshoot the issue:
  1. Check the USB cable: Make sure that the USB cable you are using is properly connected to both the camera and the computer. Try using a different USB cable to see if that resolves the issue.
  2. Check the USB port: Try connecting the camera to a different USB port on your computer to see if the port is the issue. Some USB ports may not have enough power to detect the camera.
  3. Install the camera driver: If the camera did not come with a driver disc, try downloading and installing the driver from the manufacturer's website. Make sure to download the correct driver for your camera model and operating system.
  4. Restart the computer: Sometimes, restarting the computer can help to resolve issues with USB devices not being recognized.
  5. Try a different computer: If the above steps do not work, try connecting the camera to a different computer to see if the issue is with the camera or the computer.
If none of these steps resolve the issue, it is possible that there may be a hardware problem with the camera. In that case, it may be necessary to contact the manufacturer or a qualified technician for further assistance.
3/17/2023 8:12:42 PM • Konica Minolta... • Answered on Mar 17, 2023
My Konica Minolta dimage A200 has recently started draining the battery very fast. Bought new batteries but the problem persists. The camera is now almost unusable.
A circuit or wire short will need to be diagnosed with a meter or send out for repair
4/9/2021 7:30:29 PM • Konica Minolta... • Answered on Apr 09, 2021
2answers
I have a damaged LCD
Consider the following: Minolta closed their camera division in 2004, and sold the operation to Sony. That's also why the later Minolta lenses are compatible with Sony DSLRs (Minolta AF mount).
However, this meant that Minolta cameras were also automatically rendered obsolete, with no new spares being manufactured / supplied. (I know, I still own some Minolta cameras and have been down this road)
Now, I'm sure you can see how slim the chances are of getting any spares for the camera in question, especially a humble Point and Shoot.
It's time to aquire something newer (imho).
5/12/2018 4:25:13 AM • Konica Minolta... • Answered on May 12, 2018
Screen says Card Locked..
Check your memory cards. If you are using SD cards, there is a small slide-lock on the side of card. Move the slide away from the LOCK icon, re-insert the card in the camera, being careful not to cause the slide to move again, and you should be able to use the card normally.
5/21/2016 3:55:04 PM • Konica Minolta... • Answered on May 21, 2016
My Digital camera says "unable to use card"... ive tried every solution, even i swith on the lock position in my adaptor, but still i doesnt work. please i need a help please...!
we would need to know what model camera you are using and what manufacturer, type, and size of SD Card you are attempting to use. Some cameras are not able to accept certain types and sizes of cards. Some may be able to with firmware upgrades.
2/11/2016 2:39:24 PM • Konica Minolta... • Answered on Feb 11, 2016
Keeps on saying err when I take a picture
You have a memory card in? Formatted?
6/14/2015 2:16:28 AM • Konica Minolta... • Answered on Jun 14, 2015
2answers
What can i do if my photocopier is showing me c400
c 400 is the exposure lamp on the copiers is failing or has failed , change it
11/26/2014 1:15:37 PM • Konica Minolta... • Answered on Nov 26, 2014
2answers
Hello i have an minolta
Hi.
Believe it or not the camera is worth around £100 or $150 dollars. If you are going to put a reserve price on the camera then i would start with £50 or $80 depending on the condition its in.
Regards.
9/20/2014 3:47:17 AM • Konica Minolta... • Answered on Sep 20, 2014
My minolta slr camera lens does not work
have you tried replacing the batteries ?
8/23/2014 4:00:36 AM • Konica Minolta... • Answered on Aug 23, 2014
How can I set the Machine to show A4 size
Hi Femi, I have this site for you where it has steps on how to do that ( number 11 ). Hope it helps. FAQ KONICA MINOLTA United Kingdom
5/8/2014 11:36:58 AM • Konica Minolta... • Answered on May 08, 2014
Konica Minolta Minolta Dynax 404 Si 35 Mm Film Camera Film Camera Logo
1 questions posted
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Cameras
Most Popular Question
use tamron 90 300 mm af macro minolta
  • Cameras
