20 Most Recent
Konica Minolta Minolta Dynax 5 35mm Film Slr Camera With 35-135 Mm Sigma Af Zoom Lensfilm J018 Questions & Answers
Konica Minolta Dimage Z6 working fine, but Windows 11 wont recognise it. Any ideas please?
If your Konica Minolta Dimage Z6 camera is working fine but is not being recognized by Windows 11, there are a few things you can try to troubleshoot the issue:
- Check the USB cable: Make sure that the USB cable you are using is properly connected to both the camera and the computer. Try using a different USB cable to see if that resolves the issue.
- Check the USB port: Try connecting the camera to a different USB port on your computer to see if the port is the issue. Some USB ports may not have enough power to detect the camera.
- Install the camera driver: If the camera did not come with a driver disc, try downloading and installing the driver from the manufacturer's website. Make sure to download the correct driver for your camera model and operating system.
- Restart the computer: Sometimes, restarting the computer can help to resolve issues with USB devices not being recognized.
- Try a different computer: If the above steps do not work, try connecting the camera to a different computer to see if the issue is with the camera or the computer.
If none of these steps resolve the issue, it is possible that there may be a hardware problem with the camera. In that case, it may be necessary to contact the manufacturer or a qualified technician for further assistance.
I have a damaged LCD
Consider the following: Minolta closed their camera division in 2004, and sold the operation to Sony. That's also why the later Minolta lenses are compatible with Sony DSLRs (Minolta AF mount).
However, this meant that Minolta cameras were also automatically rendered obsolete, with no new spares being manufactured / supplied. (I know, I still own some Minolta cameras and have been down this road)
Now, I'm sure you can see how slim the chances are of getting any spares for the camera in question, especially a humble Point and Shoot.
It's time to aquire something newer (imho).
Screen says Card Locked..
Check your memory cards. If you are using SD cards, there is a small slide-lock on the side of card. Move the slide away from the LOCK icon, re-insert the card in the camera, being careful not to cause the slide to move again, and you should be able to use the card normally.
Hello i have an minolta
Hi.
Believe it or not the camera is worth around £100 or $150 dollars. If you are going to put a reserve price on the camera then i would start with £50 or $80 depending on the condition its in.
Regards.
