20 Most Recent Maytag M7Y15F2A Air Conditioner Questions & Answers
0answers
No power to thermostat
First check the safety of the air conditioner in the electrical panel of the house, then Check if the socket has power that you put the extension cord and placed an interference power from other priza.an everything is OK then something is going to board the air conditioner
10/19/2011 6:38:08 PM • Maytag M7Y15F2A... • Answered on Oct 19, 2011
Need owners manual online what is the auto button
Auto enables the unit to adjust the temp automatically as temp in the room changes. It will change to cool mode or high fan according to the temp in the room.
8/1/2011 7:14:28 PM • Maytag M7Y15F2A... • Answered on Aug 01, 2011
My air conditioner turn off
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
6/7/2011 2:07:53 PM • Maytag M7Y15F2A... • Answered on Jun 07, 2011
What is the maytag#m7y15f2a Air Conditioner worth
could not find your item online, whats is the BTU, and also the power supply, and age. Thats all you really need for pricing.
3/15/2011 5:06:22 PM • Maytag M7Y15F2A... • Answered on Mar 15, 2011
0answers
Kenmore model 58072187300 a/c and heat window
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heating element check power toelement. If power is there but still no heat means element defective. Replacenew heating element. Thanks
1/10/2011 8:49:46 AM • Maytag M7Y15F2A... • Answered on Jan 10, 2011
My air conditioner turned itself off and now the
Remove the unit from the window,and dissassemble and use a water hose and clean the inside of the unit,remove all debris,this is most likely the problem.
7/10/2010 6:36:06 PM • Maytag M7Y15F2A... • Answered on Jul 10, 2010
The lowest setting is 66 and it does not cool my
I would advice you add freon on the air conditioner because when such device is low on freon, the cooling rate will be reduce drastically, also, in addition, i suggest you get the air pressure pump to blow both the surface and inner part of the air conditioner because when dust are clog on the surface, it affects the cooling, with this, i believe the performace should improve.
Take care and thank you for contacting fixya.
7/10/2010 1:30:59 PM • Maytag M7Y15F2A... • Answered on Jul 10, 2010
2answers
Unit makes a loud compressor noise when running
As long as it cools and you can sleep I would say no. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
6/12/2010 4:02:36 AM • Maytag M7Y15F2A... • Answered on Jun 12, 2010
Cord and plug where A/c unit is plugged into is
Your unit needs a plug that is on it's own circuit. As it draws alot of amps. So anyother device take it out of the circuit. Now that is to fix the warm plug problem. And the ice up coils is another problem, if you can take it out of window and remove the cover can you examine the coils? Sounds like it needs cleaned very well. with garden hose and let it dry out good before setting it back in window. Let me know how it goes okay..... ken
5/9/2010 2:00:53 PM • Maytag M7Y15F2A... • Answered on May 09, 2010
Not cooling - M7Y15F2A-B
Here is a tip that will help you to troubleshoot your A/C unit..
Air Conditioner2_bing.gif Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
4/15/2010 2:59:42 AM • Maytag M7Y15F2A... • Answered on Apr 15, 2010
Remote sends signal a/c/ won't respond,also
as for the remote,with a nail board (used for finger nails) lightly sand off the battery and battery contacts,with this file because such low voltage 3 v.d.c.(on the remote control) any corrosion on contacts even tho you can't see it can't pass current needed for proper operation/as for the compressor,replace the start relay and overload on the A/C unit and you should be good to go again
3/19/2010 3:15:42 PM • Maytag M7Y15F2A... • Answered on Mar 19, 2010
Maytag M7Y15F2A Air Conditioner Logo
41 questions posted
Top Maytag Heating & Cooling Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Heating & Cooling
Most Popular Question
need owners manual online auto button
  • Heating & Cooling
