20 Most Recent
IBM ThinkPad X41 Notebook Questions & Answers
Turn off num lock
when you power up puter, go into your bios setup, you can turn your num lock off in there.
My computer will not boot windows xp os
Do you mean it won't pick the disc? If so, try
F10 it should also give you a boot menu if you don't see press any key to boot from cd... The other option is boot into BIOS and change your boot order. CD-ROM/DVD should be the 1st option.
IBM X41 TABLET TUCH PAD DRIVERS
Get onlineand got to www.google.com In the google search box type: "IBMSupport" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad drivers.
Ibm x41 will not boot says boot overload
Have you tried booting in Safe Mode?Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
My brother gave me an
The power connector needs to be soutered back onto the board.
Here is a tutorial.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
My computer worked fine until
This error message could be caused by :-
Check the BIOS to see if it detects the hard disk
If not the hard disk may be faulty or needs reseating. If the hard disk is faulty it needs to be replaced and Windows installed on the new hard disk.
A virus program may have infected the computer and removed or changed some system files - in this case Windows needs to be repaired OR Windows re-installed - this is the best option.
I don't know how enable infrared port in my pc -
By default, currently available ThinkPads come with the external serial port disabled and Infrared enabled on COM1. To use the serial port on COM1 you must either disable infrared or change infrared so that it uses alternate resources. If you are not using infrared for printing or file sharing it is recommended that it be disabled. Here are the steps to follow to enable infrared :
1. Double-click your ThinkPad Features or ThinkPad Configuration icon located in the ThinkPad folder on your desktop.
2. Locate the Infrared button located on the left-hand side of this configuration screen and click it once. (Note: If you hold your mouse pointer over any of the icons in this configuration screen the button will be identified at the bottom in the status window.)
3. Change Infrared from "Disable" to "Enable" and click "OK".
4. Locate the serial port icon and click it once.
5. Select serial port "enable" and insure that the COM PORT setting is "COM 1" and click "OK".
6. Shut down and restart the computer.
Reset administrator password on thinkpad x41
if you want to reset bios startup password then you need to remove the cmos battery on the motherboard.....
if you are try to reset windows administrator's password then it can not be reset unless you have set your system to superuser or another administrator user
