20 Most Recent
Canon Pixma MP800 All-In-One InkJet Printer Questions & Answers
Problem Code: 155,0,0
the solution is so much easy.
the problem in short is that there is a conflict with other device on the system.
for example, if there is a usb flash drive connected to your pc, just remove it and then try to scan again
and everything is going to be alright.
Error code 6a00
AP position error.An error occured in the AP motor during purging operation.
Can't print cd label
Somewhere in your supplied software you'll have Canon Easy-Photoprint.(If not, download it, if it supports your printer) It leaves a small tray of buttons on your screen if set to start with Windows. It's got a CD label button, and on my i9000pro, you don't have any other settings to worry about. You probably thought this was a noddy programme not worth installing, but it has its uses. Hope this helps.
My canon mp800 printer, is
hi..
1.unplug the cable then plug it ...
2.did u reinstall it? try to remove it on ur computer then re-install it..
hope helped u
regards..
Describe your canon pixma mp800 troubleshooting
IF! It does not print the blue >1 have u replaced the cartrage> 2 is it flashing if so get a resetter and reset the cartrage> 3 if not remove all cartrages and remove cartrage head soak in 50% water 50% ammonia over night rinse with clean water shake out excess water "do not ! " rub dry with a towel but pat it dry. If u have a water pick when rinsing out, use it to pressure wash the receiver screens in the head. let head set by a heater vent over night. Might want to speed up drying time by using a hair dryer. Good Luck This has save me many times if printer has not been used and set 4 a long period of time . PS THIS 50/50SOLUTION ALSO WORKES GREAT FOR CLEANING PAINT BRUSHES.
