20 Most Recent
Canon PIXMA iP6220D InkJet Photo Printer Questions & Answers
Printer cuts off power immediately.
You are not supposed to move the cartridges manually?? When you go to change the cartridges and you open the door, the cartridges move to the center so you can change them....when you close the door, they go back to the corner... .
Erroe code 5B00
Keep Hold Power Button and Press and Hold the Reset Button Keep Hold the Power Button and Press Reset Button 2 Times Unplug and replug the cables Check Restart the Printer
My Canon PIXMA iP 6220D
CLARIFY PLEASE. YOU CLEANED IT ACCORDING TO THE INSTRUCTION MANUAL, RIGHT?
WHAT IS THE PROBLEM WITH THE DISPLAY? WHAT DO YOU NEED HELP WITH, BE SPECIFIC. IS IT UNDER WARRANTY? DO YOU HAVE THE TROUBLE SHOOTING GUIDE? IS THERE AN ORANGE CODE # IN THE PROBLEM BOX? YOU CAN ALWAYS CALL CANON DIRECT.
I have Canon Pixma IP6220D When I turn on the
Hi
I had same problem: when the printer needs more current to move the cartridges, the power supply switches off. To solve it, I replaced a broken diode in the power supply unit, and now the printer works fine.
