20 Most Recent Canon MultiPASS MP370 All-In-One InkJet Printer Questions & Answers
Motherboard battery was disconnected
perform the setup once again since all previous data/setting has been lost when the battery was disconnected
5/21/2022 9:18:00 AM • Canon MultiPASS... • Answered on May 21, 2022
0answers
0answers
Where can i buy a
1.Parts are available exclusively by calling the Canon customer..To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance.
2.You can buy a print head for your printer from http://www.precisionroller.com/print-heads-for-canon-multipass-mp370/products.html
or
http://www.worldclassink.com/Canon-QY6-0054-000-QY6-0054-Printhead-item3655.html
9/19/2011 1:12:06 AM • Canon MultiPASS... • Answered on Sep 19, 2011
0answers
Black ink printing incorrectly.
Hi
Try to clean it manually by removing the ink cartridge and then clean the print head with softcloth with rubbing alcohol. Then rub again the printhead into a plain paper until ink flows. Then try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
4/20/2011 7:36:28 PM • Canon MultiPASS... • Answered on Apr 20, 2011
Is MP370 - Windows 7 compatable ? I cannot install
Yes, it is Windows 7 compatible. You can find the drivers for the printer at the link below. Just download and install the driver for your computer and the printer should be installed. If it doesn't install that way open up control panel, go to devices and printers, go to add a printer, choose local printer, use the default port and click next, choose have disk and select the drivers that you just installed, then just click next through the rest of the wizard. Just make sure you can print a test page.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/multipass_series/multipass_mp370#DriversAndSoftware
4/10/2011 8:45:31 PM • Canon MultiPASS... • Answered on Apr 10, 2011
Printer ink overflow full, how to fix myself
as far as I know, there's a kit for that from canon that you can buy by calling tech support.
3/3/2011 1:18:24 PM • Canon MultiPASS... • Answered on Mar 03, 2011
I've seen this problem answered
> have cleaned & deep cleaned the printer head,
If your printer isn't used often, the print-head is likely clogged and no amount of machine 'cleaning' will restore it to function. Your problem caused me to abandon ink-jets forever and go with a laser printer. I used to maintain inkjets and the only method that seemed to have any effect on a clogged print-head is either replacement of the head and have had limited success by soaking the print-head in household ammonia for hours and finally bought an ultrasonic cleaner and used the ammonia bath to free up clogged heads. After having serviced these turkeys for two decades, I finally tired of the necessity of cleaning print-heads for the few printing tasks I still do. The very early HP inkjets were pretty good at lasting through a few days of non-use but the technology was also much coarser than the current units. I LOVE my Samsung CLP-310; it ALWAY prints when I need it.
3/1/2011 1:41:55 AM • Canon MultiPASS... • Answered on Mar 01, 2011
It keeps saying put in cartridge, if you change
You need to replace the printhead of the printer
1/22/2011 2:19:32 AM • Canon MultiPASS... • Answered on Jan 22, 2011
2answers
"Waste Ink Level Full" appears on my printer,
With this type of Printer you will need to contact Canon and find a near by printer repair center. They should be able to replace the waste ink absorber kit in your printer in about an hours time provided they have the kit on-hand. I would not try to replace it youself due to that fact that theres many parts inside and some printers have timing wheeling inside them.
Canon Customer Care Center at 1-800-OK-CANON
Besst of luck...
11/22/2010 7:34:45 PM • Canon MultiPASS... • Answered on Nov 22, 2010
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
Popular Tags
102 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
MultiPASS Canon
  • MultiPASS Canon
Most Popular Question
buy
  • Office Equipment & Supplies
