20 Most Recent
Canon DC10 DVD Camcorder Questions & Answers
I want 2 have my canon manual camcolder
You may download one from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=361&modelid=11816
I just insert a 4G micro card and says card
Check your mini SD card and see if it has the SDHC (high capacity) logo on it. Originally SD cards, including the mini SD, had a 2GB limit by protocol. The DC10 was introduced when this was the most advanced protocol. Since then the SDHC protocol has been introduced, but the DC10 is not compatible with SDHC. You need to get a mini SD, 2GB maximum capacity.
Canon DC10 with an Apple Mac
I think you need a firewire connection for video, is there another socket on your camcorder? you can download short mpeg videos to iPhoto via usb
No instructions or software
Here is the website where you can download the Manual in PDF and Driver for your Canon DC10. But the available driver is for win98, winME and win2000 only. copy this site "http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=361&modelid=1181". Hope it helps.
Can not transfer video from Canon DC10 to Laptop
the way you can transfer your videos on your computer is by using USB cable and install the driver to your computer. You can upload your videos by saving it on ULEAD products. As far as i know you cant transfer videos from disc to your memory card unless it was been converted but you cant view or watch it on your camcorder itself only computer can play this because your camcorder is not able to play such converted files.
i will give you a step by step on your camcorder.
- connect your camcorder using your USB cable to your computer and be sure it is ON
- Install the cd driver camed with your camcorder. if you didnt prompt on looking for a driver then go to the add hardware on the control panel and follow the procedure there.
- after the installation you should see the icon on the my computer labeled scanners and cameras and indicating the model of your camcorder.
- Install Ulead Power Producer or any editing movie that you have like Windows movie maker, nero movier maker etc.. i prefer to use Ulead because its so easy to use
- after uploading and editing your videos using ULEAD save it on any various types of videos that you like. you should see it after you want to save it.
- burn your videos on NERO software
Hope you understand my procedures. Good Luck!
Canon dc10 problem
Finalizing - try keeping it plugged and finalizing
ALSO
you can pnly use the roxi program to upload files
It came with that CD
so install the program
and if you want to use Windows Movie Maker
or something else like that
export the file form roxio program
