20 Most Recent Canon PowerShot SD550 / IXUS 750 Digital Camera Questions & Answers
2answers
Soke coming out of the top of my camera
its probably already on its way out. I am wondering why you are asking such a question on a forum rather than taking it straighyt to a camera store to have it fixed before it becomes totally fused.
Longer you use it ij this condition the more it will cost to fix
Please rate my help++++Thanls for using FIXYA
12/1/2018 11:23:32 AM • Canon PowerShot... • Answered on Dec 01, 2018
0answers
0answers
E18 help fix
I am sorry my vivitar 990HD will not format cards, I have tried the lock on the side of the card in all positions. Ihave tried different cards (which is not a cheep thing to do) and nothing is working. The guy at Best Buy said their is a problem with the internal card reader. I would like to know what I can do to get it fixed.???????????? I would appreachate any help you may give me. Thank you very much. Mike
10/1/2013 11:37:10 PM • Canon PowerShot... • Answered on Oct 01, 2013
2answers
I wiped all photos from card...but when I
You should make it a practice to format (initialize) your card from your camera's menu each time you use it. That will wipe all data and give you a clean start. If you format your card from your camera and it still indicate a full memory card, then the card is likely bad.
3/14/2013 8:05:05 PM • Canon PowerShot... • Answered on Mar 14, 2013
Halo around main subject
Check for dirt on the front element of the lens. I am always amazed that almost every point and shoot digital I see has a filthy lens.This can also be caused by condensation inside the lens or on the rear element
2/4/2013 1:21:45 AM • Canon PowerShot... • Answered on Feb 04, 2013
I cant transfer the photos from the camera into a computer!
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
11/25/2012 4:03:20 AM • Canon PowerShot... • Answered on Nov 25, 2012
How do i set my
Set the Photo Effect to "B/W". For full details see the "Changing the Photo Effect" section of the advanced guide (page 57 in my copy). If you need the manuals, you may download them from here.
11/17/2012 12:45:47 AM • Canon PowerShot... • Answered on Nov 17, 2012
Date and time function
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
11/17/2012 12:45:19 AM • Canon PowerShot... • Answered on Nov 17, 2012
Dowloading pictures
11/17/2012 12:40:28 AM • Canon PowerShot... • Answered on Nov 17, 2012
My canon SD 750 camera does not read the sd card even when the sd card is not locked, how do i unlock the internal switch in the camera for the sd card?
Could be faulty sd card and you may need to try another one to see if you get the same message.
11/6/2012 6:42:12 AM • Canon PowerShot... • Answered on Nov 06, 2012
Sd550 door latch
Pick a color from here.
7/10/2012 8:31:12 PM • Canon PowerShot... • Answered on Jul 10, 2012
Lens won't retract on SD550
Try resetting the camera by removing the battery for 20 mins. then replace the battery go to the camera's menu and set the Date and Time.
5/31/2012 2:55:34 PM • Canon PowerShot... • Answered on May 31, 2012
Lens stuck
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
11/20/2011 3:41:30 PM • Canon PowerShot... • Answered on Nov 20, 2011
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
230 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
sd550 door latch
  • Cameras
