20 Most Recent
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Questions & Answers
Waterproof case
no they wont it will not be the right fit try to find the right one for your camera i had the same promblem as u did and it didnt work soo try as hard as u can to find the right one for u
Format restoration
Hey seasea911,
I've read nothing but good things about Art Plus Digital Recovery software, but if it's not working I would keep trying different software until I find one that works. I would make sure your SD card is not set to the locked position before trying to recover your images.
Sincerely,
Allan
Go Ahead. Use Us.
Black screen on camera
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Driver updates
Do you really need a driver?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
