20 Most Recent Canon PowerShot A430 Digital Camera Questions & Answers
2answers
Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
11/2/2021 2:52:25 AM • Canon PowerShot... • Answered on Nov 02, 2021
Canon PowerShot A495 - Brand
Get it fixed under warranty.
10/31/2017 3:48:06 AM • Canon PowerShot... • Answered on Oct 31, 2017
2answers
BLACK SCREEN... CANNON A430
press display botton
12/29/2015 9:48:13 AM • Canon PowerShot... • Answered on Dec 29, 2015
Pictures taken outside in sunlight are white while indoor OK
Automatic settings are stuck probably due to moisture. Too expensive to fix, get another camera. Try ebay. Price start at $15 to $395 refurbished - new. And free shipping. Repairs start at $50-75 just to take a look inside.
9/30/2015 4:09:46 PM • Canon PowerShot... • Answered on Sep 30, 2015
13answers
Canon Powershot A430 horizontal lines problem
have opened my camera. (it was useless anyway, right?) GUess what I found: in the lens-assembly there is a ribbon cable that controls the two solenoids, one of the shutter, one of the diafragm (or what it's called). This one is broken, the electric circuits are discontinued and so there is no control. It seems to be a design error since it broke exactly where the ribbon bends at 180 degrees almost with no place for a loop most of the focussing time. Can anyone find out where to find a NEW replacement ribbon cable? 847a466.jpg
12/29/2013 7:43:38 AM • Canon PowerShot... • Answered on Dec 29, 2013
Memory card error
What type and size memory card? The A430 works with SD and MMC cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
9/27/2013 4:27:33 PM • Canon PowerShot... • Answered on Sep 27, 2013
Can't find the driver
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Canon ZoomBrowser or Picasa ( http://picasa.google.com ).
8/18/2013 3:37:25 PM • Canon PowerShot... • Answered on Aug 18, 2013
Horizontal line pictures
am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
3/27/2013 10:34:58 AM • Canon PowerShot... • Answered on Mar 27, 2013
Black Screen
Try hooking up your camera to your computer VIA USB. Power on the camera and see if your computer see's the Camera. If you do not have your cable just try and take a picture. Then pull the memory card out and see if you can see the picture you just took. If the camera still works you could try the link below. More then likely if the camera works you broke the screen. http://www.smashedhat.com/sd300repair/
12/17/2012 7:54:45 PM • Canon PowerShot... • Answered on Dec 17, 2012
2answers
Canon A430- Overexposure and Horizontal Lines
it is not flex cable only it is CCD it self as well so they are right CCD with Flex need to be changed but Canon is doing it FREE all over the world just go to authorised service centre there and send an email to Canon and they will arrange all things FREE i am pretty sure pls give it a try
pls rate me well SEE THIS
12/5/2012 3:50:12 PM • Canon PowerShot... • Answered on Dec 05, 2012
Can i use aa lithium batteries
Yes.
11/25/2012 9:05:22 PM • Canon PowerShot... • Answered on Nov 25, 2012
Memory card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
11/25/2012 9:05:17 PM • Canon PowerShot... • Answered on Nov 25, 2012
How can i show the
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
11/25/2012 9:05:12 PM • Canon PowerShot... • Answered on Nov 25, 2012
I have canon a430 its
11/25/2012 9:03:58 PM • Canon PowerShot... • Answered on Nov 25, 2012
Lents error
11/25/2012 9:02:31 PM • Canon PowerShot... • Answered on Nov 25, 2012
Hello, I`ve bought a 4GB memory
The A430 works with MMC and SD cards. It will not work with SDHC cards. You need to use SD or MMC cards, 2GB and smaller.
11/25/2012 9:02:19 PM • Canon PowerShot... • Answered on Nov 25, 2012
Canon PowerShot A430 Digital Camera Logo
225 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
black screen cannon a430
  • Cameras
