20 Most Recent
Canon PowerShot S3 IS Digital Camera Questions & Answers
How to take Supermacro pix?
Super Macro will not work in "auto" mode. If you put it in "P" mode
(and possibly the other manual modes) and then press the "macro"
(little flower looking think) button to the left of the lens under "MF"
(manual focus). It will display "hold for super macro" on the screen.
Profnohair
Canon PowerShot S3 IS & Windows 7
This is correct. The S3 is discovered by windows 7 and will allow download of pictures by Windows Picture download. The Canon Utilities software - Zoombrowser - will not work with windows 7 as the software cannot detect the Camera via Windows 7.. Also, Camera window will not start, if using the PC/laptop for remote image recording. If you virtualise XP within Windows 7 this still will not work. The only solution at the moment, if you are deperate, like I was (as I use the Remote Capture process a lot), is to either stick with Win Xp or Dual boot XP on a smaller partition.
Why can I not get my Canon PowerShot S3 IS to switch to the PLAY mode?
Search Results
gdlp01.c-wss.com/gds/3/0900001323/01/PSS3ISCUGba-EN.pdf
Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
www.imaging-resource.com/PRODS/S3IS/S3ISA3.HTM
Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
archive09.linux.com/feature/118946
Linux.com
Canon S3 Lens Error
There two possible scenarios:
1. Sand particles got stuck in the internal lens mechanism. Try in remove them with compressed air, blowing it through the camera lens openings. If this does not work, then here are the bad news.
2. Either the lens internal gears are damaged, the ultrasonic motor is damaged, or sand particles are really stuck inside the lens.
It does not matter which of the three reasons are casuing the problem, but the camera needs to be opened by a qualified technician, defined thereason of the failure, and quoted the repair service, unless you are willing to do it yourself, but it requires a complete disassembly of the camera, and I don't recommend it unless you have the experience and skills in fixing electronic devices.
Best regards,
Black screen for Shooting Canon S3 I
Your camera has a stuck shutter. There is a guy on eBay that fix this issue for a low price. Fix is for Canon S2, S3, S5 with stuck shutter. here is the link in case you need: http://www.ebay.com/itm/141414188140
Canon PowerShor S3 not functioning
Had my S2 IS now for 3 years , never had a problem with the lens. I'm careful not to bump my lens into anything. I actually bought the lens hood and put a filter on my lens so that no dirt can get into my lens or I can't accidentally bump my lens into anything while i'm using it as it's protected by the adapter and filter.
