20 Most Recent
Canon imageCLASS D320 Digital Copier Questions & Answers
ALL COPIES BLANK. NOT LOW
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
Install cartridge message displaying on my machine
When your cartridge is not adjust properly.
install your old cartridge.If this massage again may be your machine .Right side drum charge lock not adjust.Or machine ready so problem on cartridge.
Cartridge part no T series toner cartridge SG 35 is appropriate model.
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if
its over 60,000 copies you need to change the developer along with the
opc drum and cleaning blade or roller,all copiers need to be replaced
with new developer,opc drum and cleanign blade or roller when it reach
its copy life,that may be the cause of light copy of print
Canon ir2020-seystm err e354 please tel me what
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
