20 Most Recent Canon ImageRUNNER 330s Copier Questions & Answers
2answers
SORRY THIS DIDN'T WORK OUT.
sure thing..just send an email to [email protected], and they should be able to get this sorted. Or else, just go back to your post and change the rating to thanks for trying or inappropriate.
However, I dont think you'll be able to find it on any forums. Your best bet would be to call Canon on their Support line.
If you wish, you can buy the service manual online, but costs like $200!!
Anyways, Cheers and good luck!
IrishDruid
12/1/2018 11:24:51 AM • Canon... • Answered on Dec 01, 2018
0answers
2answers
On copier sow display bord "Swith main power off and on E001
When switch on ImageRUNNER 330s Grayscale Copier then no display on dispaly board. But Copier front yellow led is on. Please solve this problem.
4/19/2014 2:50:50 AM • Canon... • Answered on Apr 19, 2014
0answers
IR 330 RESET PASSWORD
Be the first to answer 1/10/2014 10:19:29 PM • Canon... • Posted on Jan 10, 2014Be the first to answer
0answers
What does a hard drive cost for a cannon 330s
A new hard drive is about $100.00..... The problem is getting some one to flash the drive with the correct software. The copier is about ten years old or soo.
1/14/2013 2:59:09 AM • Canon... • Answered on Jan 14, 2013
Replace removed hard drive ,cost?
The hard drive is on the back side of the copier behind the rear panel. The hard drive is not expensive, the problem is getting the hard drive flashed with the correct software. Also, it is a older copier... It may not be worth repairing????? Good Luck
1/14/2013 2:57:24 AM • Canon... • Answered on Jan 14, 2013
Obstructed copy
Typically when labels come off the paper, the get stuck on the Fuser (the heating rollers just as the paper exits the machine) Open up the printer and turn the round hand that you would clear a jam with, and look on the roller to see if they are stuck there.They are also known to get stuck in the paper tray or pickup assembly. Follow the paper path through the machine and you will find them.Good Luck
6/4/2012 11:33:05 PM • Canon... • Answered on Jun 04, 2012
Black smudges
that is the life time of drum is over. you must change it
2/6/2012 4:01:58 PM • Canon... • Answered on Feb 06, 2012
I replaced the toner in
u can replace the dp unit or composite power supply pcb
10/26/2011 6:51:55 PM • Canon... • Answered on Oct 26, 2011
How to clear RAM using factory settings in CANON
ir 330 and ir 400,gp 405 r same machine,turn on the copier when its ready to copy press the additional function then press (2 and 8 both r same time) again additional function when this process is completed copier on the screen select that in the screen find the 'function' select then select on clear in clear menu select one by one err and other all function like dc-con and press ok after se;ect one by one..
10/26/2011 6:49:51 PM • Canon... • Answered on Oct 26, 2011
Canon Imagerunner 330s Added new toner
Try to look at these notes:
1. Charge - Print Quality (PQ) -- The charge roller evenly distributes a negative charge on the photoconductor (PC) drum. This evenly distributed charge acts as the film that is discharged (exposed) by the laser to create the latent image.
a. Print Quality effected: Faint, Entire Black background, Grey Fog/Haze
b. Parts Involved:
i. Drum -- A drum cartridge is coated with a photoconductive material that allows electricity to pass when exposed to light. As an example of why this can be the failure, if you leave a drum out in light long enough, you will get dark backgrounds or just black pages. However, drums do wear out over time too; specifically the photo material the drum is coated with. As this degrades, more of the positive electricity on the inside of the drum gets through and grabs toner, as if the laser wrote to every square inch of it. A damaged or defective PC drum can cause black streaks/lines, voids, speckles and various other print quality problems.
ii. Charge Roller - Also known as the BCR or Bias Charge Roll. The charge roller pulls double duty. It energizes the outside of the drum with negative energy and as a result it cleans any previous latent images. If the charge roller were failing to energize either due to the HVPS or the charge roller itself, it wouldn't clean any previous unused toner deposits from the last revolution would start to accumulate and appear on paper more and more causing haze. A missing charge roller causes completely black pages.
iii. HVPS - High Voltage Power Supply -- Responsible for charging components such as the inside of the drum, the charge roller, and transfer roller. If the HVPS does not give enough to the charge roller it can fail in erasing the drum, causing entirely Black pages to be printed.
Hope this sheds any light on the issue that you have. Thanks for using Fixya.
9/12/2011 3:36:13 PM • Canon... • Answered on Sep 12, 2011
2answers
I have install the iR3245
I see you are having issues with the ID and password of the driver from the shared printer.
It may not work since Win XP and Win 2k3 may have a different mapping language, But I believe inorder for you to save the ID and password you can always install the driver of the printer in the Win XP having the ID and password stored on the driver, then you can try to map again and see if the ID and password after mapped will be an issue.
8/7/2011 7:32:07 PM • Canon... • Answered on Aug 07, 2011
I attempted to print a
Just DELETE Your Installed Printer,And Re-install with PS drivers.
8/4/2011 4:03:44 PM • Canon... • Answered on Aug 04, 2011
I have a canon imagerunner
Sounds as though the lifting mechanism for the paper Pick-up assembly has gone bad. When closing the paper cassette you should hear a ratcheting sound, this is the lifting of the paper to meet the paper pick up rollers. It should stop and the display should indicate paper is present. If it continues to ratchet and never indicate the paper is ready, then the P/U assy will be the problem. The whole paper pick-up assembly will have to be replaced. In all my years of working on this model, I never successful in repairing the assembly.
6/27/2011 7:03:15 PM • Canon... • Answered on Jun 27, 2011
108 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
replace removed hard drive cost
  • Office Equipment & Supplies
