20 Most Recent
Panasonic PV-GS32 Mini DV Digital Camcorder Questions & Answers
Lines during playback
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9/3/2011 5:36:17 PM •
Panasonic...
Answered
on Sep 03, 2011
Lcd screen is not coming
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
11/15/2010 5:01:03 PM •
Panasonic...
Answered
on Nov 15, 2010
The battery won't take a
Batteries are available at partstore.com, thats where i buy most of my repair parts. I hope this helps.
9/6/2010 6:14:44 PM •
Panasonic...
Answered
on Sep 06, 2010
Cannot capture video from Panasonic DV Camcorder
Check if ur firewire cable is this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
Once connected,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
3/10/2009 5:29:56 AM •
Panasonic...
Answered
on Mar 10, 2009
My computer does not detect
It should be detecting .. else try this... I hope you are using the 4 pin to 4pin firewire cable which looks like this:
Switch on the Cam.
3/10/2009 5:24:07 AM •
Panasonic...
Answered
on Mar 10, 2009
Video playback is distorted and has no sound
Usually head cleaner tapes do not do much more than wear the heads out and move the dirt around or in some cases if it is an old tape it may add dirt to the system!!! Someone needs to remove the cassette cover and clean the video drum, tape path, pinch roller and capstan with denatured alcohol. Do not use anything but 100% alcohol as anything else will have contaminates in it. The video head pole pieces are extremely small (we're talking microns) and can be plugged easily. Cleaning the tape guides, audio heads, erase head, capstan and pinch roller is pretty straight forward and the same as any audio deck. Using a lint free Q-tip (or special head cleaning sticks from electronic stores) dip in alcohol and remove any dirt etc from the pieces. Cleaning the video drum is a little trickier. Using the same kind of cleaning stick dipped in alcohol, gently wipe around the video drum assembly. Never, ever go up and down across the face of the head or you could break the video heads!! If you do not know the proper way to do this you should take it to a qualified tech or you could do more damage than good. If you clean your unit the way that I described it should be fine. On occasion I have had a unit with a clogged head that requires a different technique to clean but you would not be able to do this. If cleaning does not work you will need to take it to a repair shop for service. Good luck.
2/24/2008 8:23:47 AM •
Panasonic...
Answered
on Feb 24, 2008
