20 Most Recent Maytag Atlantis MAV7551 Top Load Washer Questions & Answers
Atlantis MAV7600AWW not spinning at all
Most likely the bearing / cam kit that releases brake is worn and not doing its job.
11/14/2017 1:17:22 PM • Maytag Atlantis... • Answered on Nov 14, 2017
Water leaks from the bottom
Main seal faulty, pump seal faulty, tub to pump hose faulty, outlet hose faulty, hole in plastic outer bowl.
12/21/2013 2:00:12 AM • Maytag Atlantis... • Answered on Dec 21, 2013
What is blck powder under the motor of belt drive Maytag washer MAV4057AWW
The powder is belt wear. Not to worry though, they last a long time. There is always some wear on all belts as they slide into the channel on the pulley.
7/22/2013 1:00:48 AM • Maytag Atlantis... • Answered on Jul 22, 2013
2answers
Maytag washer is full of water at end of cycle
Replace the timer.
5/7/2013 8:05:34 AM • Maytag Atlantis... • Answered on May 07, 2013
2answers
I have a Maytag Atlantis Washer. At first it
post model number please
12/15/2012 1:06:32 AM • Maytag Atlantis... • Answered on Dec 15, 2012
Ok, so I have a maytag atlantis serial number MAV7650AWW. Everything worked fine up until a couple days ago, the washer just stopped working it was full of water and seems as if it has no power at all
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
6/26/2012 11:23:20 AM • Maytag Atlantis... • Answered on Jun 26, 2012
I got the top off the washer, and now I cannot
Most don't have a front panel. Just top panel and rear panel.
Did you raise the top panel?
There are clips there that you have to find with a flat knife type tool.
6/27/2011 7:29:26 PM • Maytag Atlantis... • Answered on Jun 27, 2011
Washing machine make noise and I need help to open
Hello, Thank You for using FixYa. I will be helping you today.There is a clip about 4 inches in from each corner between the top and front panel. You need to push in with a putty knife and lift on the top, When top is open there are two screws one on each side holding the front on remove them and lift front off.
Thank You and please rate my answer if it was helpful..
6/25/2011 4:10:37 PM • Maytag Atlantis... • Answered on Jun 25, 2011
Washer spins on delicate only. Won't spin on
Hello, Does it sound like its spinning in regular and just not spinning? If So You may just need to replace the belt. Also this unit the motor pulley would melt and break. Lean the unit back and you can see the belt and pulley. Hope this helps and please dont forget to rate me. Thank You...
6/8/2011 2:19:48 PM • Maytag Atlantis... • Answered on Jun 08, 2011
Leaking water out the bottom.
where in the bottom? could be a simple tub to pump hose or is it coming from the tub seal around the transmission.
2/19/2011 5:37:44 PM • Maytag Atlantis... • Answered on Feb 19, 2011
After the wash has finished, water still trickles
Needs a new fill valve
11/4/2010 4:33:56 AM • Maytag Atlantis... • Answered on Nov 04, 2010
Maytag washer belts running but tub not spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
7/12/2010 1:35:32 AM • Maytag Atlantis... • Answered on Jul 12, 2010
Will fill with cold water but not hot
the hot water inlet valve is shot replace it
4/28/2010 3:06:05 AM • Maytag Atlantis... • Answered on Apr 28, 2010
I replaced the brake, brake stator, and snubber
most likely a bad water pump/remove belt and turn pump by hand , you'll be able to tell if its the pump by the way it turns,should turn smoothly in both directions
3/6/2010 9:07:35 PM • Maytag Atlantis... • Answered on Mar 06, 2010
Maytag Atlantis MAV7551 Top Load Washer Logo
46 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
washing machine make noise need help
  • Washing Machines
