20 Most Recent Panasonic Lumix DMC-FX01 Digital Camera Questions & Answers
FX-01 was good camera in it's day but it has been out for 12 years and times have changed. That said, you can still get 1GB and 2 GB SD old-style cards on ebay and other sites. By the way, why hunt for a way to shoot on a 4GB+ card anyway? Low resolution (this one is 6mp) digital cameras with high capacity cards is a recipe for disastrous data loss. As long as your original cards for this camera are not corrupt just keep re-using those.
Panasonic Lumix... | Answered on Jan 09, 2018
it is just a battery and camera manufacturers use generic batteries
take the old battery out and all you need is a battery the same shape , voltage and composition --ni-cad or metal hydroxide
they would be available at any camera shop or online from e-bay
Panasonic Lumix... | Answered on Nov 23, 2017
It will work with any SD card, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Panasonic Lumix... | Answered on May 01, 2014
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Panasonic Lumix... | Answered on Oct 02, 2013
Remove the battery for 15 mins, replace the battery then go to the camera's Menu and set the Date & Time.
Panasonic Lumix... | Answered on Mar 15, 2013
The FZ20 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Panasonic Lumix... | Answered on Feb 22, 2013
This problem comes out for lance issue,if you are technician then open your camera and proper clean your lance, or put to any repairer for service your camera properly , don't warry its a routine problem of camera .
Khatricamera@gmail.com
Panasonic Lumix... | Answered on Nov 13, 2012
I don't know about buying one, but you can download a copy for free here.
Panasonic Lumix... | Answered on Oct 08, 2012
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Panasonic Lumix... | Answered on Aug 30, 2012
It appears you cannot take RAW images.
You can download the manual from this WEB site.
http://www2.ph.ed.ac.uk/acoustics/teaching/acoustics/PanasonicDMC-FX01Manual.pdf
Panasonic Lumix... | Answered on Aug 26, 2012
If the message persists, take the camera to the nearest sevice center.
Panasonic Lumix... | Answered on Jul 16, 2012
Lens is stuck. Buy from ebay the same parts camera that has a good lens but maybe bad lcd to make repair.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Just about any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Panasonic Lumix... | Answered on Jun 19, 2012
If your panasonic camera uses a panasonic battery and you try to use a different brand equivalent battery, some panasonics will not work. Could that be your problem?
Panasonic Lumix... | Answered on Nov 11, 2011
Panasonic Lumix DMC-FX01 Digital Camera Logo
136 questions posted
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
lumix panasonic dmc fz20 camera keeps
  • Cameras
