20 Most Recent Maytag Atlantis MAV9501E Top Load Washer Questions & Answers
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
3/16/2017 1:15:32 PM • Maytag Atlantis... • Answered on Mar 16, 2017
0answers
Sharp washing machine es s701x
What is your problem ? Not washing, making noises, no spinning, no draining, shaking, what ?
8/25/2013 10:39:50 AM • Maytag Atlantis... • Answered on Aug 25, 2013
Top load washer spins but
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
8/13/2011 9:02:36 PM • Maytag Atlantis... • Answered on Aug 13, 2011
I have a maytag atlantis
The not completly filling and squeeling makes me want to look at the screen on the water valve that the hoses attach to on the rear of the machine for blockage preventing water flow,to me the squeeling is the solonoids on the water valve calling for water yet no water coming in. IF you manually fill the washer using buckets of water/a hose what will happen? perhaps try that!!
Also if you have the "aquaflow flood stop" hoses the internal stopper in the hose is bad,replace hoses using standard hoses
Good luck,i hope this helps you to fix your washer,
Gene
8/9/2011 6:10:59 PM • Maytag Atlantis... • Answered on Aug 09, 2011
Washer makes loud noise on spin cycle
Hi, it sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new machine to have someone come out and repair it for you. It sounds like Kenmore has had a bearing problem which is pretty ridiculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warranty is usually conveniently expired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves.
6/16/2011 9:01:52 PM • Maytag Atlantis... • Answered on Jun 16, 2011
Model MAV9501EWW not spinning but it is pumping
Hello & Welcome to FixYa
When the washer is not spinning however, pump out the water then the problem is with the lid switch that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
1/13/2011 7:00:52 PM • Maytag Atlantis... • Answered on Jan 13, 2011
Maytag Atlantis Model Number MAV9501EWW
Hi.
Test and eventually replace the inlet valve.
The inlet valve is tested reading impedance, if it is broken, then it usually read infinity (circuit open). Reaing is done disconnecting valve and pointing multimeter probes at valve solenoid contacts (the cold ones in your case).
A definitive test on inlet valve is done reading volts while cycling and observing if valve is opening. For safety reasons is better if the user performs only tests that can be done with power off.
The switching contacts and inlets is also a test even if basic, I think that the valve is gone.
Here part:
Series 21 models: sub 22004333 (water inlet valve)
Series 12 models:VALVE-INLET
Valve is part nr.2 in diagram below. Click on the picture to enlarge.
If you repute this solution helpful, then please do not forget to accept.
Best regards.
Ginko.
10/1/2010 4:08:26 PM • Maytag Atlantis... • Answered on Oct 01, 2010
Hi, Our Maytag washer (model
Remove the two screws at bottom of front panel and
pull panel out from the bottom.
9/12/2010 11:06:09 PM • Maytag Atlantis... • Answered on Sep 12, 2010
My cold water won't work. I can get hot water but
replace the hot water valve!!!!!!!
5/15/2010 12:58:41 PM • Maytag Atlantis... • Answered on May 15, 2010
Motor hummed and smoked, smelled electrical
If the motor smells foul it is fried and needs to be replaced
5/12/2010 1:54:28 AM • Maytag Atlantis... • Answered on May 12, 2010
Washing machine not spinning, just screeching.
It sounds like the belt is slipping and will need to be replaced.
I hope this helps. If I can help in any way please let me know.
3/20/2010 8:40:23 PM • Maytag Atlantis... • Answered on Mar 20, 2010
Does not spin
door switch need to be replace or bypass :) dont slam the door next time ..
1/2/2010 9:27:18 PM • Maytag Atlantis... • Answered on Jan 02, 2010
The washer grinds while washing.
check the pulley on the pump they have a common thing of the pump pulley comming apart and grinding if not fixed it will melt the motor pulley and belt
12/31/2009 6:19:41 AM • Maytag Atlantis... • Answered on Dec 31, 2009
There is no cold water only hot and the machine
Not enough information, but I'm assuming you have 2 inlet water valves. 1 hot water and 2 cold water. Possibly you connected the hot water to the hot water valve. It must go to the cold water valve instead. Not good to run the washing machine like that as it will bring other problems into play. (colours running, plastic distorting etc.). That's if it is very hot water.
10/10/2009 4:57:12 AM • Maytag Atlantis... • Answered on Oct 10, 2009
Loud spin cycle - leaks water
No boot on a top loader, the tub seal and bearing are gone, water leaked from the tub seal, rusted the bearing and quite possibly the milk stool and transmission. Check your warranty, the transmission may have a 5 year limited warranty, usually it will include the tub seal and bearing with the kit.
6/13/2009 2:29:17 PM • Maytag Atlantis... • Answered on Jun 13, 2009
Problems with MAV9501EWW Washing Machine :(
your seals and bearings are bad do you wash a lot of sandy gritty clothes if you do that is the cause of the problem
5/10/2009 11:26:31 AM • Maytag Atlantis... • Answered on May 10, 2009
Maytag Atlantis MAV9501E Top Load Washer Logo
41 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
sharp washing machine es s701x
  • Washing Machines
