Hey friend, thank you for your post!
You are able to purchase parts with the coating already applied for your Electrolux refrigerator, E23CS75DSS. To answer your question, there is no way to fix the bubbling issue on your appliance you would have to purchase new parts for your refrigerator. I have included the parts manual link so you can look over parts needed. Once you have those parts numbers needed you can reach out to the manufacture to order them. I hope this is helpful. -Matt Frigidaire Manual Search Results
Electrolux Refrigerators • Uploaded on Aug 19, 2013
Hi
Please check this link bellow to troubleshoot your problem:-
http://www.ehow.com/how_2306100_fix-refrigerator-water-dispenser.html
Please get back to us if you have further query else please accept the suggestion.Thank you for contacting fixya.com
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer or evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan to see if it is running.If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
45 questions posted
42 Questions
24 Questions
