20 Most Recent Maytag MAH55FLB Front Load Washer Questions & Answers
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
1/8/2018 11:54:33 AM • Maytag MAH55FLB... • Answered on Jan 08, 2018
Spinning very noisy.
Hi avenick05,
The noise you are hearing might be the Drain pump catching on a foreign object.
Please look at my Tip below on how to clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
7/27/2011 11:06:52 AM • Maytag MAH55FLB... • Answered on Jul 27, 2011
Speed error displayed on screen
u need to get a sevice manual to show u how to fix it .and u can go to appliancerepairplanet.vstore.ca for this
12/1/2010 5:55:51 PM • Maytag MAH55FLB... • Answered on Dec 01, 2010
2answers
Odor
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
9/28/2010 4:17:56 PM • Maytag MAH55FLB... • Answered on Sep 28, 2010
Short water fill cycle
clean the water hose sc reens
10/5/2009 1:18:25 AM • Maytag MAH55FLB... • Answered on Oct 05, 2009
Maytag neptune front load odor
affresh.com
your welcome
12/19/2008 1:15:02 PM • Maytag MAH55FLB... • Answered on Dec 19, 2008
Why would my Maytag Neptune front load washer stop draining water
Troubleshooting chart-
https://machinecompanion.com/maytag-neptune-washer-not-draining/
4/4/2024 4:19:35 AM • Maytag Washing... • Answered on Apr 04, 2024
Need to ID Maytag dryer with no label?
The label should be at the back where the power goes in. The label is supposed to be not able to be removed (strong adhesive or metal and riveted. There may also be a service manual and wiring diagram in the top console. Pictures and mentions here, but no model details. You could also try emailing Maytag. https://www.google.com/search?q=maytag+ensignia+heavy+duty+super+size+capacity+quiet+series+200+10+cycles You can upload pictures, but we know what the machine is because of your excellent description. After more searching it may be MDE4806AYW although it says 12 cycles? https://www.google.com/search?q=maytag+%22ensignia%22+heavy+duty+super+size+capacity+quiet+series+200+10+cycles+manual ..
3/28/2024 12:22:21 AM • Maytag Washing... • Answered on Mar 28, 2024
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>> So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced. From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue capture-o5w4phgx25od3lsv3yfk4e0a-4-0.png Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail. Helpful? Good luck on your troubleshooting!
3/27/2024 11:50:27 PM • Maytag Washing... • Answered on Mar 27, 2024
Maytag top loading washer with UL code
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
2/19/2024 1:57:34 AM • Maytag Washing... • Answered on Feb 19, 2024
2answers
What would be causing my commercial Maytag triple load washer to blow the fuse just before the load of wash is finished it started doing it about 3 days ago
Could be as the spin starts it overloads the fuse ..... not sure without more information though.
2/10/2024 8:23:45 AM • Maytag Washing... • Answered on Feb 10, 2024
Maytag Bravos XL quiet series 300 keeps giving Ld codes. It is not the pump. How can I determine what the issue is?
Ld is long drain, so either the pump is blocked, the pump impeller is worn or the drain hose is blocked. I had a drain blockage on a Miele and it was cause by an apple stalk lodging itself across the ridges of the drain hose and had collected enough lint to block it, This was a machine that was washing towels commercially for 16 hours a day. Unhook the drain and watch it pumping either into a bucket or into a laundry sink. It should fly out in a jet! ..
1/30/2024 4:39:51 AM • Maytag Washing... • Answered on Jan 30, 2024
Where is the counterweight in my Maytag washer model MVWC565FW2
If yours is a top loader it will mounted near the drum inside the machine. It will be a shaped block of concrete curved to sit close the actual drum. The most like places will be at the front, nearest you when your putting clothes in it, at about 3/4 of the way off the floor. It could also be in a similar place at the back of the machine.
1/2/2024 12:12:14 PM • Maytag Washing... • Answered on Jan 02, 2024
Maytag dishwasher leaks mdb4100aww
Unfortunately, if you can't get to it, you need a new machine. Normally you would seal with silicone or epoxy putty. The only thing I can can think of is injecting polyurethane expanding foam into the area, but go easy it expands for 10 minutes and you would have to shield any moving parts. Most parts are obsolete.
MDB4100AWW Maytag Dishwasher - Overview - PartSelect
PartSelect https://www.partselect.com > Models > MDB4100AWW A complete guide to your MDB4100AWW Maytag Dishwasher at PartSelect. We have model diagrams, OEM parts, symptom-based repair help, instructional videos, ... ..
12/31/2023 5:22:46 AM • Maytag Washing... • Answered on Dec 31, 2023
Maytag MVWB300WQ1 hums when power pressed. Continues after powering off. Only stops when unplugged.
Humming is indicative of the start/run capacitor on the motor failing. I am puzzled though why it carries on humming until you unplug it? Having said that, a capacitor is an electronic store of power. https://www.google.com/search?q=maytag+mvwb300wq1+capacitor+replacement ..
12/30/2023 12:01:45 AM • Maytag Washing... • Answered on Dec 30, 2023
Maytag MAH55FLB Front Load Washer Logo
14 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag neptune front load odor
  • Washing Machines
