20 Most Recent
Kyocera Km-6030 With Feed, Finisher, Bank, Print, Scan - 270k Copies Questions & Answers
How can i solve the code 0060 on my machine km-6030
Enter service mode 1087twice key pad in 935 the you follow these steps
Setting
1. Press the start key.
2. Select the item.
Initial setting: MODE0
3. Press the start key. The setting is set.
4. Turn the main power switch off and on.
Supplement
After removing the cause of the problem, be sure to change the setting in OFF.
C3300 code
I am living in a Pakistan Village and have cyocera K-6030. I am facing an error on control pannel C3300, I would be most grateful, if I may be informed only that in which part of the machine this fault of C3300 is? it solution please. Thanks with regards. my e mail no is
[email protected] and
[email protected]. If some one here can show me its solution, because my e mail is also not opening. thanks. my name is ghulam muuhammad
How to solve the km 6030 machine error code c7200
Hi Farid,
Error Code c7200 means : Broken internal thermistor wire • The thermistor output value is 4.5 V or more.
Because of : Poor contact in the connector terminals. Defective developing humidity sensor.Defective engine PWB.
Need to replace the defected part. please visit to the nearest service center.
Thanks
