20 Most Recent Maytag MAH20PD Front Load Washer Questions & Answers
2answers
Maytag MAH20PD washer does not do the High Spin Cycle
with what you have described the problem should be in the door lock unit. there is a check switch that gets pressed down and sends a signal to the computer board telling it that it is locked. if the switch isn't working then that signal will not be sent and the washer will just turn and never enter spin. replace the switch and this will clear up the problem
12/19/2011 6:09:15 PM • Maytag MAH20PD... • Answered on Dec 19, 2011
Water dont spin out of clothes all the way
you may have obstruction in pump remove hoses off the pump and cheak for any objects.
11/27/2010 12:27:50 AM • Maytag MAH20PD... • Answered on Nov 27, 2010
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
2/28/2009 1:28:37 AM • Maytag MAH20PD... • Answered on Feb 28, 2009
Why would my Maytag Neptune front load washer stop draining water
Troubleshooting chart-
https://machinecompanion.com/maytag-neptune-washer-not-draining/
4/4/2024 4:19:35 AM • Maytag Washing... • Answered on Apr 04, 2024
Need to ID Maytag dryer with no label?
The label should be at the back where the power goes in. The label is supposed to be not able to be removed (strong adhesive or metal and riveted. There may also be a service manual and wiring diagram in the top console. Pictures and mentions here, but no model details. You could also try emailing Maytag. https://www.google.com/search?q=maytag+ensignia+heavy+duty+super+size+capacity+quiet+series+200+10+cycles You can upload pictures, but we know what the machine is because of your excellent description. After more searching it may be MDE4806AYW although it says 12 cycles? https://www.google.com/search?q=maytag+%22ensignia%22+heavy+duty+super+size+capacity+quiet+series+200+10+cycles+manual ..
3/28/2024 12:22:21 AM • Maytag Washing... • Answered on Mar 28, 2024
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>> So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced. From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue capture-o5w4phgx25od3lsv3yfk4e0a-4-0.png Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail. Helpful? Good luck on your troubleshooting!
3/27/2024 11:50:27 PM • Maytag Washing... • Answered on Mar 27, 2024
Maytag top loading washer with UL code
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
2/19/2024 1:57:34 AM • Maytag Washing... • Answered on Feb 19, 2024
2answers
What would be causing my commercial Maytag triple load washer to blow the fuse just before the load of wash is finished it started doing it about 3 days ago
Could be as the spin starts it overloads the fuse ..... not sure without more information though.
2/10/2024 8:23:45 AM • Maytag Washing... • Answered on Feb 10, 2024
Maytag Bravos XL quiet series 300 keeps giving Ld codes. It is not the pump. How can I determine what the issue is?
Ld is long drain, so either the pump is blocked, the pump impeller is worn or the drain hose is blocked. I had a drain blockage on a Miele and it was cause by an apple stalk lodging itself across the ridges of the drain hose and had collected enough lint to block it, This was a machine that was washing towels commercially for 16 hours a day. Unhook the drain and watch it pumping either into a bucket or into a laundry sink. It should fly out in a jet! ..
1/30/2024 4:39:51 AM • Maytag Washing... • Answered on Jan 30, 2024
Where is the counterweight in my Maytag washer model MVWC565FW2
If yours is a top loader it will mounted near the drum inside the machine. It will be a shaped block of concrete curved to sit close the actual drum. The most like places will be at the front, nearest you when your putting clothes in it, at about 3/4 of the way off the floor. It could also be in a similar place at the back of the machine.
1/2/2024 12:12:14 PM • Maytag Washing... • Answered on Jan 02, 2024
Maytag dishwasher leaks mdb4100aww
Unfortunately, if you can't get to it, you need a new machine. Normally you would seal with silicone or epoxy putty. The only thing I can can think of is injecting polyurethane expanding foam into the area, but go easy it expands for 10 minutes and you would have to shield any moving parts. Most parts are obsolete.
MDB4100AWW Maytag Dishwasher - Overview - PartSelect
PartSelect https://www.partselect.com > Models > MDB4100AWW A complete guide to your MDB4100AWW Maytag Dishwasher at PartSelect. We have model diagrams, OEM parts, symptom-based repair help, instructional videos, ... ..
12/31/2023 5:22:46 AM • Maytag Washing... • Answered on Dec 31, 2023
Maytag MVWB300WQ1 hums when power pressed. Continues after powering off. Only stops when unplugged.
Humming is indicative of the start/run capacitor on the motor failing. I am puzzled though why it carries on humming until you unplug it? Having said that, a capacitor is an electronic store of power. https://www.google.com/search?q=maytag+mvwb300wq1+capacitor+replacement ..
12/30/2023 12:01:45 AM • Maytag Washing... • Answered on Dec 30, 2023
Maytag LSE1000 Got the top off the machine but can't move top off because of all the attached wires. Is the only way to remove wires?
es, in order to remove the top of a Maytag LSE1000 washing machine, you'll need to first disconnect any attached wires. This is because the wires are connecting important components like the control panel and the sensors to the rest of the machine. Here are the steps you can follow to safely disconnect the wires:
  1. Unplug the washing machine: Before you begin, make sure to unplug the machine from the power source to prevent any electrical shock.
  2. Locate the wires: Look for the wires that are connecting the top of the machine to the rest of the machine. They should be near the back of the machine where the top and bottom halves of the machine meet.
  3. Label the wires: Label the wires so you know which wire goes where when you're ready to put the machine back together. You can use masking tape and a marker to label each wire.
  4. Disconnect the wires: Gently pull the wires from their connectors, making sure to keep them separated so they don't get tangled. Be careful not to pull too hard, as this could damage the wires or the connectors.
  5. Repeat the process for all the wires: Repeat the process for each wire until they're all disconnected.
Once you've disconnected all the wires, you should be able to remove the top of the machine. Make sure to keep the wires organized and in a safe place while you're working on the machine. When you're ready to reassemble the machine, simply reconnect the wires in the reverse order you disconnected them.
12/19/2023 4:00:11 PM • Maytag Washing... • Answered on Dec 19, 2023
2answers
My friend has a Maytag maxima washer. It has water under the spinner . It won't spin out and reads codes e02 f06?
Found this...check it out... https://www.justanswer.com/appliance/8xplq-maytag-maxima-front-load-washer-error-codes-f06.html Part here.... https://www.repairclinic.com/Shop-For-Parts?query=W10374126 or here too and less money. They both have videos on how to replace it and 800# tech help. Call them before ordering to confirm this is the fix. Best to you.
12/2/2023 6:15:38 AM • Maytag Washing... • Answered on Dec 02, 2023
Looking for a Maytag seal upper pump part W912529. Again, can you help?
Yes, it is replaced by a part with a different part number. https://www.google.com/search?q=maytag+seal+upper+pump+part+%23w912529
11/10/2023 6:03:22 AM • Maytag Washing... • Answered on Nov 10, 2023
Maytag MAH20PD Front Load Washer Logo
7 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag mah20pd washer not high spin
  • Washing Machines
