20 Most Recent
DeLonghi CF210 Portable Air Conditioner Questions & Answers
E4 Error
york hvac unit e4 error code Troubleshooting
DeLonghi PAC A120E Pinguino 12,000-BTU Portable Air Conditioner - Water Leakage Problem
I had the same problem and found a fairly simple solution. UNPLUG THE UNIT FIRST. All left and right reference below is as view from the BACK of the unit (NOT from the front). Open the right side panel (right as view from the back), by removing six screws (remove screw covers first) and pull down on the panel to remove. Towards the UPPER-back of the unit, there is a cold air evaporator(?)(bunch of tubes and fins) you can only see the edge of it after removing the right panel. Below it is a white plastic drip tray with a hole at the end allowing water to pass down to the lower warm air radiator(?) (another bunch of tubes and fins) to evaporate. If this hole is obstructed, water will over flow and leak. I cleaned out the hole with a vacuum attached to a drinking straw, you might have a better way. After cleaning, I poured a little water through to make sure it drains. There is a lower drip tray at the bottom of the unit which catches the water and you can drain it out the bottom drain hole by unplugging the rubber stopper at the back bottom of the unit. The lower drip tray has a float switch (you can only see it by removing the back panel, which you don't have to do for this procedure) which turns off the unit when the lower tray is full. So, theoretically, even if the evaporation is not working properly, as long as the upper drain hole is not obstructed, there should not be any leakage, because the water will drain into the lower drip tray and turn the unit off when it is full. The upper drain hole obstruction might be causing most of the leakage problem. Also make sure the unit is level left to right. If the left side (left as viewed from the back) is lower than the right side (as view from the back) the water in the upper drip tray might not flow to the drain hole properly and might overflow. You should also vacuum and clean the upper plastis filter screen (pull it out from the top back of the unit). Before closing the right side panel, you might want to vacuum and clean the lower warm air radiator, be careful not to damage the fins. Again before you start any of this, UNPLUG THE UNIT FIRST. This might be easier than packing and sending the over 90 pounds unit to an out of town service center. I understand some service centers might charge $100 for a simple cleaning. Consult a trained technician if you don't have the skill to do this. Do this procedure at your own risk because I am not sure if it might void you warranty. Again UNPLUG THE UNIT FIRST before you start.
I have ft error on delonghi air conditioner and
Theres a little floatation type device in the removable tank that triggers a switch just above the tank on the unit itself. Just check that that isn't stuck in the "Full Tank" position. I had the same problem and jiggled the switch to make sure it could move and my A/C was back. Hallelujah!!! Hope it works for you...
Error e6 displaying on single split model one
I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication malfunction. So can you tell me how can I fix it
Extension cord is black delonghi cf210)
well , yes , it could be fixable , but first the adapter is a three prong to two prong adapter ? if so , for your safety I recommend to plug A/C UNIT wheres a three hole outlet , using the adapter eliminate the UNIT to be grounded , there for causing problems like cord getting hot. hope this helps
Fan comes on; however, can't get the desired
Hi Kate, When you press the button for your desired temperatre setting it will show this temp' say 17*c for a few seconds then it will revert back to showing the actual room temp' say 23*c, it should then cool the room down to what you set it at. hope this helps.
Delonghi cf208 the dehumidifier mode does not seem to do anything, any suggestions
I have the same model. It works brilliantly as we tend to dry the washing inside this time of year. When on dry mode try turning the "set temp" down to 17'c this normally starts mine off,,, failing that put some washing in a warm room with the dehumidifier "temp set" at 17'c just to test it maybe. or perhaps its just not humid enough where you are placing it? Good luck.
Leaking water
It has to be drained regularly. Buy and install an appropriate size and length tubing to it.
