I had a similar problem with my 42 in Philips LCD HDTV. My TV would turn off by itself, then not at all.
Here was my problem and it likely yours as well. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. This is a sure sign of failure. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional.
Remember, TVs CONTAIN HIGH VOLTAGE. Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board can cost in the hundreds. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. You can find TV repair kits online to repair this problem but it takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Good luck to you.
14 questions posted
300 Questions
174 Questions
154 Questions
131 Questions
120 Questions
