20 Most Recent Panasonic TH-50PX60U 50 in. Plasma HDTV Questions & Answers
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
Panasonic... | Answered on Jan 07, 2018
First step check fuses then if they are bad replace them, also check the voltages on the various test points on the power board
Panasonic... | Answered on Dec 03, 2017
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Panasonic... | Answered on Jul 18, 2017
it could be bad arial reception
Panasonic... | Answered on Mar 26, 2017
Check the led circuit if you have sound. Inverter circuit or led themself. Good luck.
Serge.
Panasonic... | Answered on May 07, 2016
did you hear the sounds? or maybe you have defective power source in hot side..
Panasonic... | Answered on Oct 09, 2015
possibly from Panasonic . or any computer store.
Panasonic... | Answered on Aug 12, 2015
if it will bring the menus up from the remote also it soundss as though the receiver has gone. Maybe that should be the tuner.
You appear to need the services of a technician to diagnose.
Before you do that reset the tv to factory default and set it up from scratch . Also check that the aerial/amtemma omsta;;atopm os pl.
Panasonic... | Answered on Jul 05, 2015
Main board. More exact to say, the main system control section IC. it is the central command section to all the functions to the TV. Gopakumar Gopalan Google
Panasonic... | Answered on Jun 10, 2015
These blinks are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Panasonic... | Answered on Oct 11, 2014
Sounds like COF [Chip On Film] fault. Contact any service technician. To get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screens are given with illustrations. You can get an idea about the fault to an extent.
Panasonic... | Answered on Sep 13, 2014
Check all the sustain boards. Contact any service technician.
Panasonic... | Answered on Aug 29, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Panasonic... | Answered on Aug 23, 2014
Both of them have different faults. One of it have fault with tuner, and the other have fault with its digital board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Panasonic... | Answered on Aug 15, 2014
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
175 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
panasonic th 50px60u 50 in plasma no
  • Televison & Video
