20 Most Recent
Panasonic TH-42PX500U 42 in. Plasma Television Questions & Answers
Logic main
What do you mean by this '
logic main"? Provide more details please.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
10/28/2013 12:32:05 PM •
Panasonic...
Answered
on Oct 28, 2013
HDMI ports do not work
I had the same problem with my integra receiver. You can use RCA plugs which will do the same thing and not use HDMI the fix is cost prohibitive from what I was told.
2/23/2013 11:06:55 PM •
Panasonic...
Answered
on Feb 23, 2013
Exit mode service
For more details type in this site name "Electro-help" (DO
NOT copy and paste the site name from here.
Doing so may lead you to wrong place) to search box of your search
engine [not in the address bar of your browser],
and press "Enter".
It is an electronic
equipments service help site.
Note the
position of hyphen in between words in site name. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site,
either at the bottom part of first search page, or at the top of second.
Detailed descriptions are there to help you.
6/7/2012 5:38:49 PM •
Panasonic...
Answered
on Jun 07, 2012
I have a 2005 Panasonic
Hello
How are you connecting the display to the laptop? what kind of cables are you using? please be very specific about the cables that you have, post any and all details you see on them.
10/6/2010 9:07:13 PM •
Panasonic...
Answered
on Oct 06, 2010
I have a Panasonic Plasma, believe model TH-42PWD6
I had a similar problem with the blue tint going away. I solved it by replacing the terminal board with a new component board I picked up on eBay. You can also use the PC input with a D-sub connector using a component cable adapter.
9/23/2010 6:51:13 PM •
Panasonic...
Answered
on Sep 23, 2010
10 Blink when you plug
Take ur tv aparts and the power supply board have a serial number on it.That the board,where the power a/c cord plug into it.Try website like Ebay.com search Panasonic TH-42PX500U plasma tv power supply board.Will,see many refurbish power supply board for sale.
9/15/2010 4:35:32 AM •
Panasonic...
Answered
on Sep 15, 2010
My Panasonic TH-42PX500U just started displaying
Hello:
If the lines are 2 or more inches wide and stationary then this could mean a bad buffer board, when ever the lines are thin less then one inches wide then this indicates a bad panel. Now if the lines are moving then its possible that you are getting a 60 cycle humm in one of your inputs. Or the power supply is causing the problem, to be honest the most common failure in panasonic plasmas is the power supply. I would turn on one source at a time to see which source is causing the problem. One of the sources may have a defective power supply and sending the hum into the unit.
9/6/2010 10:07:25 AM •
Panasonic...
Answered
on Sep 06, 2010
Panasonic 50
This sounds like a bad logic board. On this model, Panasonic calls it the "D" board aka Format Converter, Plasma AI Processor. It takes the video info from the main board and processes it for the display panel. Repair is board replacement.
4/17/2010 11:13:51 PM •
Panasonic...
Answered
on Apr 17, 2010
2 year old daughter cratched my plasma screen with
Your plasma cover screen should be glass, not plastic. I have no knowledge of Panasonic or any other manufacture that made a plasma TV with plastic....all plasma TV's have a glass cover. Clean the surface with a rubbing alcohol solution and a cotton ball.
2/6/2010 4:33:17 AM •
Panasonic...
Answered
on Feb 06, 2010
