20 Most Recent
Breville SK500-XL Stainless Steel Cordless Electric Kettle Questions & Answers
Switch has stopped working, kettle will not heat water
Hi Bruce or anyone else that has this problem.
I had this problem too and after pulling the base off I found that the switch was ok but the problem lay with the two bi-metallic thermal overload switches that are connected to the heating element. I managed to reset them both and now the kettle works fine. This can become an issue if you have accidently boiled the kettle dry once in it's life. Best of luck.
4/14/2012 8:07:21 AM •
Breville...
Answered
on Apr 14, 2012
Light switch on Breville SK500-XL Kettle
e mail
[email protected]
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
2/21/2009 4:10:09 PM •
Breville...
Answered
on Feb 21, 2009
Intermittently working
That means that there is either a lost contact inside, or a defective switch.
The kettle must be taken apart to fix the problem.
12/27/2008 5:13:29 PM •
Breville...
Answered
on Dec 27, 2008
How do i get the screws out of a breville toaster
I took a 3/16" common (straight) screwdriver bit from one of my cheap universal driver bit sets, chucked it vertically in my shop vice, mounted a grinding disk in my Dremel tool, and ground a 1/16" wide by 1/16" deep slot in the center of the bit. It worked perfectly. A hacksaw blade carefully placed could produce the same tool.
