20 Most Recent
Panasonic PT-52LCX65 44" HDTV Questions & Answers
Just replaced our blub in
jlamina19,
You could have a bad optical engine, but first try this tip. Remove the lamp assembly again and make absolutely certain that everything is inserted and seated correctly. If this does not help you may have damaged your optical engine when the lamp quit. They can get very hot before failure and this could have damaged one of the TFT panels. I have a tip to explain how to change the engine at
http://www.fixya.com/support/r4251975-replace_dlp_light_engine.
Thanks for using FixYa and for the great rating.
hardrocko
9/15/2014 9:49:57 PM •
Panasonic...
Answered
on Sep 15, 2014
Panasonic lcd projection tv has first a pink spot
The pink spot and later green spots indicates the screen is at faulty,
The light engine is defective. The part is an entire assembly. It is about $650. You can get this parts from ebay.com or shopjimmy.com.
Hope this help in solving the problem..
9/15/2014 9:42:44 PM •
Panasonic...
Answered
on Sep 15, 2014
TV won't power on
Sounds like the bulb is not firing. I have the 44 inch model. Like it too. It is normal for the power indicator to blink for a minute or two AFTER the set has been turned off from running. get a phillips or panasonic TY-LA1000 bulb or a P22H 120 watt one if you can remove the old one from the housing (not very hard to do).
5/8/2014 8:21:06 PM •
Panasonic...
Answered
on May 08, 2014
How to reset lamp timer on panosonic PT56DLX75
NOTE: If the "Please Replace Lamp" message is displayed, press [RETURN] or [EXIT] on the remote to remove the message. 1. Turn the unit ON. 2. While pressing the [VOL-] button on the unit, hold down the [SPLIT] button on the remote at the same time for more than 5 seconds. 3. When the reset procedure is completed, the following message is displayed on the screen: "LAMP TIME WAS RESET TO 0".
3/11/2014 3:39:26 PM •
Panasonic...
Answered
on Mar 11, 2014
HDMI stopped working tonight!
I used an HDMI
The HDMI is a digital signal connector, in the tv is handled and decoded separately from the analogue connectors. Because of that the tolerances on the signal characteristics are much tighter so , if the chip is damaged even in the slightest way, it can no longer process the signal. The video from the Xbox is displayed because the signal generated there is most likely at the limits of the tolerances.
This is a hardware fault, that no reset will fix: the AV processor is faulty and the only way to fix that is to replace the motherboard.
12/28/2013 9:45:34 PM •
Panasonic...
Answered
on Dec 28, 2013
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
11/10/2013 4:39:35 PM •
Panasonic...
Answered
on Nov 10, 2013
I have panasonic pt52lcx65 it kept saying to
Howdy,
YES, the TV was telling/warning you that Lamp was going out soon so you would not be without the use of your TV while you get a Lamp.
Thanks for using FIXYA, BIG IRISH.
4/28/2013 3:16:14 AM •
Panasonic...
Answered
on Apr 28, 2013
