20 Most Recent
Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher Questions & Answers
My dishwasher gets stuck with one minute remaining
Welcome to FixYa.
Based on your description I'd say the issue actually is with the control...unfortunately. This is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated. Copy & paste this link (or click on it if it will respond) to your toolbar (explorer bar ?) and you'll see my complete solution for this issue.
http://www.fixya.com/support/t8763034-good_afternoon
I also wanted to add, depending on your model and serial number Bosch issued a recall on some of their units. Here's a link you can use to check up on your specific unit.
http://microsites.boschappliances.com/safetyrecall/dishwasher/
Good luck.
Regards,
Macmarkus :)
Bosch dishwasher she44c05uc won't drain
If there were 2 seeds, are you positive there are no more? Try flicking the impellor by hand, if it moves then check for voltage at the pump when running. If no voltage, then pcb, if voltage then pump
Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Bosch dishwasher door will not
Hello, dcmckenzi
I was trying to help
you out here. Maybe this will help some? I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Bosch SHE44C07UC/22 - FD8606 :
Hi 2ipnelson,
Very difficult to know for sure which part is not working.
It is best to run the dishwasher in testing / service mode to ascertain which component is not working.
I found a .pdf document that explains the whole process, it should also work for your SHE model.
The link:
LINK - CLICK HEREFollow the steps, and the culprit part should be diagnosed.
Hope this helps :-)
* If this solution helped you, please accept it
