Mine dishwasher (a Maytag) did this also. At first it was becoming stuck because of the soap. My repair guy cleaned it and I switched to liquid soap and it worked great another 2 years then did it again. That time it was just wore out and had to be replaced. I was told it was no longer available but we found it here http://www.repairclinic.com/and our repair guy installed it. He was amazed because he had even called everywhere.
Quorahttps://www.quora.com > What-does-CL-mean-on-a-dish...
This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ...
9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
JustAnswerhttps://www.justanswer.com > Appliance Repair
Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone.
1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your
..https://www.youtube.com/watch?v=Xr4DBwACUW4
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in.
https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31
DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31
As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet.
AI Bot Answer Deleted.
In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
