20 Most Recent
HP L1706 17" LCD Monitor Questions & Answers
Monitor is changing color when
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Dear Sir,
I have installed Ubuntu
that is what happens using new pc, new os. like linux
and then using old monitor ! welcome to PnP H3LL
1024 reso is very very old. we long ago exceed this era.
both MS and linux do not try to support the old dead no longer supported by makers, monitors.
try to imagine how many different monitors were made in last 30 years. vast.
then try to support the ones not supported now.
you do know the HP does not support 10 year old products right?
so knowing that one fact, how can Ubuntu...
study the limits of PnP, plug and play, its great but not magic,
it cant pull rabbits (dead) out of hats, now.
Btw, Walfart has new monitor for $46 , that works pnp.
ever consider a cheap upgrade?
now the real place to ask, not here.at fixya (guess yah)
https://ubuntuforums.org/forumdisplay.php?f=326
Shadowing of text
YOU ARE EXPERIENCING THE EFFECT OF GHOSTING.
iT CAN BE FIXED
cREATE A 1200X1600 100% WHITE .GIF TO USE AS A SCREEN SAVER. (IN WINDOWS YOU CAN ADD IT TO MY PICTURES SLIDESHOW)
Set this slide show to run after 2 minutes of non use.
Set the nonitor to power off in a short amount of non use.
say 15 minutes.
Do that for a couple of days and the ghosting affect will go away . You can then turn to a more reasonable screen saver.
I received this information from www.beginnercode.com
