20 Most Recent Maytag Performa PAV2200 Questions & Answers
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Maytag Performa... | Answered on Feb 27, 2018
check youtube for a lot of vids on this subject
Maytag Performa... | Answered on Feb 14, 2018
A transmission problem, I doubt it is worth the repair cost.
Maytag Performa... | Answered on Nov 03, 2017
Check that the exhaust hose is clean and not obstructed or kinked. Clean it from A to Z every six months!
Does the dryer heating at all?? .
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Maytag Performa... | Answered on Nov 02, 2017
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Maytag Performa... | Answered on Oct 21, 2017
without being hands on to test we can not really say what the problem is SORRY
Maytag Performa... | Answered on Oct 20, 2017
Faucet hoses are reversed, obvious!
Maytag Performa... | Answered on Oct 03, 2017
A serious transmission problem, I doubt that it is worth the cost of repair, sorry.
perhaps a service call from MAYTAG
Maytag Performa... | Answered on Sep 15, 2017
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Maytag Performa... | Answered on Mar 07, 2015
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
Maytag Performa... | Answered on Nov 13, 2014
Washing Machines Logo
655 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
wrong washer fills spins advances but
  • Washing Machines
