20 Most Recent Maytag Atlantis MAV5000 Questions & Answers
check the fuse
Maytag Atlantis... | Answered on Jul 02, 2011
Depends on model.
For top load units with two belts under botton panel, tilt empty washer against a wall to allow access to belts and loosen the 3 pump mounting screws. See page: http://www.applianceaid.com/maywash_belt.html
Maytag Atlantis... | Answered on May 07, 2011
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Maytag Atlantis... | Answered on Jun 08, 2010
if no visible adjustment nut, then you need to replace new belt may be it already wornout and not capable pulling.
Maytag Atlantis... | Answered on Mar 31, 2010
HI.
Lift the washer up and see if drum drive belt is broken or direct drive coupler is defective.
Maytag Atlantis... | Answered on Mar 29, 2010
The pump belt has to be adjusted correctly or the drive belt will slip. If it already slipped enough to burn the new belt, you will probably need another drive belt.
Maytag Atlantis... | Answered on Jan 06, 2010
Maybe could be, but it also could be that you have too many items in there. I have had the same problem and thought it was shot, then took some out and tried, worked like a charm. Good luck
Maytag Atlantis... | Answered on Oct 01, 2009
sure..start by re leveling the unit, with a standard carpenters level.
Maytag Atlantis... | Answered on Apr 24, 2008
If there is a LOCK button hold it down for 15 seconds
Maytag Washing... | Answered on Jan 16, 2020
Washing Machines Logo
23 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
washer will not come
  • Washing Machines
