20 Most Recent
Maytag MAV6200 Top Load Washer Questions & Answers
Need manual for maytag atlantis washer model
Hello, This Dr Maytag MIke.This is your lucky day!! I am going to help you out for free, and give you several manuals for your unit. Service manual, Installation Manual, Owners manual and more. You will know more about your Maytag they Maytag does. All I request in return for my free help, is to rate me and some kind words would be nice, Thanks Dr. Maytag, Mikehttps://www.maytag.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%206-2611110.pdfhttps://www.maytag.com/digitalassets/MLPDF/Installation%20Instructions%20-%2062610010.pdfhttps://www.maytag.com/digitalassets/MLPDF/Dimension%20Guide%20-%20DMATLWSH-DD.pdfhttps://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20MAV6200AWW.pdfAND FINALLY HERE IS THE LINK TO MY PERSONAL PAGE OF ALL MY AREAS OF EXPERTIZE.
http://beta.fixya.com/users/mc1beanThanks again, and happy washing. Mike
I have a nine year
Hi
The drain pump assembly requires cleaning...you'll have to
take it apart to clean the drain pump assembly. If after cleaning the issue
returns then the drain pump should be replaced. Please check this video on how
to clean/replace the drain pump assembly:
Hope this helps...please post back for further assistance.
Daniel
MAV-3 top load washer makes loud squeaky noise
Is it a constant squeak or does it go squeak-squeak - squeak as it agitates? It is a squeak that is intermittant then usually your brake is losing its hold. You will need a technician to do this job. It requires special tools that they should have. I repeat a technician should do this job. You can seriously hurt yourself attempting this repair. Also see if the inner tup is turning as it agitates, if it is then it i definately the brake. But one more time do not try this repair it is a dangerous repair that should be left to technicians. There is a spring that is under heavy compression that requires a tool to release it.
I have a Maytag Atlantis MAV6200AWW washer. It
Hi
You could have a worn out drive pulley/cam not raising the brake far enough to release or a leaking tub seal has rusted and locked the spin bearing up.
Remove front, tilt the machine back against a wall, remove the drive belt and turn the main transmission pulley, (the one in the center of machine), one way will make it agitate the other should make the pulley raise up on the cam ramp and release the brake letting the transmission turn. When you turn the pulley in the direction for spin, if the transmission doesn't want to turn try grabbing hold of transmission and turn it by hand while turning pulley.
If the ramp on the pulley/cam has worn down you can do a tempory fix by installing a thicker or extra washer between part ref# 4 and 6 to compensate for the worn cam ramp. Also check all parts in ref#24 to make sure all thrust washer and bearings are intact.
Do you notice any signs of water leakage at the top of the transmission, if so this would indicate the center tub seal has been leaking water and frozen up the main spin bearing.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Machine was spinning, was out of balance,
Some where on the machine I do not know were because different model put them in all places. you will find a reset button this should be red press it and release it an machine should work again. Best of luck
