20 Most Recent
Maytag Atlantis MAV8000 Questions & Answers
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
Maytag Atlantis...
Answered
on Nov 16, 2012
Maytag Atlantis top loader washing machine won't
The drain hose is plugged or kinked or the drain pump is not working. Check and clear the drain hose from any debris that might be causing the water not to be pumped out. After checking and clearing the drain hose and the water is still not pumped out of the washer, check the pump to see if the impeller is good or the pump needs to be replaced. Access to the pump requires the top cover and the front panel to be removed. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
The top cover is attached to the front panel by two clips positioned at about 3 inches from the corners. Use a putty knife and insert the blade into the seam between the top cover and the front panel assembly at the position of the clips.
Push the putty knife blade against the clips, one side at a time while lifting the cover to disengage the clips. Lift the top cover off the front panel then remove the two screws securing the front panel to the upper front corner braces of the cabinet.
Lean the top edge of the front panel away from the cabinet and lift the panel to disengage its bottom from the base clips. Move the front panel away from the cabinet to access the pump.
Disconnect the pump inlet and outlet hoses from the pump then remove the three screws mounting the pump assembly to the base of the washer.
Slide the pump to the rear of the washer to disengage the belt from the pump pulley and pull the pump assembly out of the washer.
Clear the pump inlet and outlet hoses for any debris to ensure water is not blocked from being pumped out of the washer.
Check the impeller. Remove the four screws securing the pump housing to the pump base then lift the housing off the base. Clean the impeller and the pump housing; replace the pump assembly if the impeller is damaged.
To replace the pump, set the pump pulley into the base opening and put the belt on the pulley. Install the mounting screws while holding tension on the belt to keep it on the pulleys.
Connect the pump inlet and outlet hoses and secure it with the clamps.
Position the bottom of the front panel back into the base clips then secure the top to the upper front corner braces of the cabinet with the two securing screws.
Push the top cover down into position to the front panel to complete the procedure.
Note: For Maytag Atlantis MAV8000A, the pump assembly is part number 35-6465.
Maytag Atlantis...
Answered
on Mar 22, 2010
Maytag top loader MAV 8000MWW
If your washer doesn't seem to work at all, check these:
No powerLid switch
No power
Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch
Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Maytag Atlantis...
Answered
on Sep 27, 2008
Maytag MAV8AWW Will Not Spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your problem will be back for someone else to solve.
Maytag Atlantis...
Answered
on May 30, 2008
