20 Most Recent Maytag Atlantis MAV7260B Top Load Washer Questions & Answers
These washer are notorious for linting, there is no real solution, reduce wash time to bare minimum, try sorting clothes into different categories, whites separate washed from dark clothes, use good quality detergent. The only way to fix this problem completely is a neutral drain kit, I do not believe Maytag sells one.
Maytag Atlantis... | Answered on Dec 21, 2013
The motor bearing are shot and won't handle the load. New motor needed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Maytag Atlantis... | Answered on Nov 19, 2010
check water supply. if good check valve. valve is probably faulty
Maytag Atlantis... | Answered on Feb 12, 2010
clean motor rollers(belt may be slipping)
9vopy...paste)
Maytag Atlantis... | Answered on Aug 31, 2009
My dryer is making a noice and will not start how do I open it to see if the belt is broke
Maytag Atlantis... | Answered on Mar 17, 2009
you don't say which model you have. one version uses two belts accesible by just tipping the machine back. Another version you must remove the front panel, and drop the pump and you'll be able to replace the one belt.
Maytag Atlantis... | Answered on Feb 04, 2009
tip machine machine back now access belt should have motor pulley, pump pulley and middle big yellow thrust bearing,, usually pump is broken
Maytag Atlantis... | Answered on Jan 03, 2009
the pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Maytag Atlantis... | Answered on Dec 27, 2008
i wouid try a new belt
Maytag Atlantis... | Answered on Feb 12, 2008
the timer might be broke, well let me explain more the prongs on the back of the timer might not be making contact so the washer will not start.
There are two methods used to hold the agitator in place. The first is a main bolt at the top of the agitator under the softener cup. The second is a small bolt located on the lower portion of the agitator. To access the transmission the tubs will have to be removed.
Maytag Atlantis... | Answered on Jan 13, 2008
Worn out drum Bearing can cause vibration and make the spin cycle very noisy.
Maytag Washing... | Answered Yesterday
Maytag Atlantis MAV7260B Top Load Washer Logo
Popular Tags
24 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag top
  • Washing Machines
