20 Most Recent
Acer (90.18612.36B) Computer Speakers Questions & Answers
No sound on my acer
Look for two speaker icons on the laptop keyboard. Locate the right side one (not the left one).
Press and hold the 'Fn' key on the bottom row. Press the above mentioned key several times to increase the volume.
Tell us what happens.
9/22/2011 5:22:07 AM •
Acer...
Answered
on Sep 22, 2011
How do i hook up
you will need to connect your speakers to your computer then you will need to install them to your computer
usually at the back of a desktop computer there is three input plugs blue green pink/red or a usb connection depending on your speakers on a laptop usually a usb connection
if your computer came with a motherboard disc the sound drivers could be on itclick start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
also click start control panel sounds and audio devices then select voice then select volume from the microphone you can increase the volume or you can test your hardware in XP in W 7 click start control panel hardware and sound manage audio devices recording right click on microphone you can configure speech recognition
or you might have to boost
hope this helps you
8/30/2011 2:57:47 AM •
Acer...
Answered
on Aug 30, 2011
How do I hook up
computer or if they are internal speakers you will need to install the sound card and the drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
untick it
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for further sound settings by right clicking on the iconhope this helps you
7/20/2011 11:54:45 PM •
Acer...
Answered
on Jul 20, 2011
I am unable to get
settings there
also
untick it
icon in taskbar
if his does not fix the
problem
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
7/14/2011 7:12:18 AM •
Acer...
Answered
on Jul 14, 2011
I got new surround sound
plug the speakers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the should be stereo (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
3/28/2011 9:20:29 PM •
Acer...
Answered
on Mar 28, 2011
My acer speakers aren't working.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
3/28/2011 9:16:57 PM •
Acer...
Answered
on Mar 28, 2011
Model 4738Z.
no sound in speakers.
also
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
3/28/2011 6:51:51 PM •
Acer...
Answered
on Mar 28, 2011
My laptop speaker is uninstalled.how
if you are having problems with your sound
also
hope this helps
3/25/2011 3:08:33 PM •
Acer...
Answered
on Mar 25, 2011
The power/vol is not working
also
hope this helps don
3/14/2011 2:38:09 PM •
Acer...
Answered
on Mar 14, 2011
No sound from speaker acer aspire computer. Which
Look down in the right corner of your sreen and find a small speaker icon. If you click on that icon it will show you if your speakers are muted, this happens sometimes by malware acting up and muting your speakers. If you right click on it it will tell you some more information. If you go into your control panel you have an icon that lets you do many more things with your sounds.
2/15/2011 10:10:23 PM •
Acer...
Answered
on Feb 15, 2011
Messed it up one day and can not ge t back too
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
1/29/2011 9:15:05 PM •
Acer...
Answered
on Jan 29, 2011
My acer was recently restored
It appears the audio driver has not been installed.
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on your laptop.Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
12/15/2010 4:07:19 AM •
Acer...
Answered
on Dec 15, 2010
Cant get computer to find
you might need some drivers
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
11/2/2010 3:31:47 AM •
Acer...
Answered
on Nov 02, 2010
Suddenly I do not have sound on my computer, it is
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
10/23/2010 1:39:48 AM •
Acer...
Answered
on Oct 23, 2010
I cannot start my computer
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will scan for and repair any bad sectors on your hard drive automatically fix any corrupt files on your hard drive or you can boot it into safe mode or safe mode with optimised defaults press f10 to save to cmos and reboot once your computer has restarted and corrected itself uninstall some unecessary programs then defragment your hard drive
hope this helps good luck
10/20/2010 3:21:53 AM •
Acer...
Answered
on Oct 20, 2010
Speakers are on but no sound
you have to re install the sound card driver you can find this download at acer.com there you can find product support and driver downloads!
8/1/2010 12:22:21 PM •
Acer...
Answered
on Aug 01, 2010
