20 Most Recent
Sony Handycam DCR-HC96 Mini DV Digital Camcorder Questions & Answers
Super8 preservation.
Hi! I will help you now. I got the name of a Hungarian company, who transferred so many reels for me. I paid about $200 incl shipping for a box of Super8 reels. Will never ever try it my self. The quality was awesome, crisp clear, wonderful restored colours, etc. The whole procedure incl. shipping time took no longer than 3 weeks. May the below link will help you. The page is only in Hungarian, but I translated it with google and bing translator. BTW the guy on the phone speaks fluently English, he used to live in the USA for many years. Just an option, as it's much much cheaper than over here and the quality is as good or even better than here...
Hope I could help.
Ne hagyja hogy kedves felvtelei tnkremenjenek
Door Jam
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Tape door won't close i
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Can't close tape door on
This problem occurs when tape mechanism got problem and tape mechanism replacement is solution.
Tape mechanism replacement in this camcorder is job of qualified tech because novice can cause more damage.
Let me know if you need tape mechanism part number info.
Thanks.
Tape Carriage won't open
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Hi there, my camcorder is DCR hc 96 and when i
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Software dcr-hc46
record on DVD RECORDER without problems and without software. good luck
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Sony dcr-hc96
I have the same problem, I was hoping it was th tapes that I was using. Hopefully Sony will fix this under warranty.
Cassette loading error 31:23
DCR-HC96 Automatic Lens Cover won't open
