20 Most Recent Sony LBT-ZX6 Shelf System Questions & Answers
My buttons on my Sony LBT-ZX6 are locked I can use the power button to turn the system on but not off and all the other buttons are locked any solutions to this problem
Most likely that any one of the buttons is stuck on possibly even on the remote(common due to liquid spill,dog chewed etc) try taking the batteries out to isolate rc. If not lightly try each button and feel if one is slightly sticking or softer touch likely to be the offender Sadly if multiple operation does not clear then unless proficient I suggest you do not try to strip down
12/25/2016 2:35:35 AM • Sony LBT-ZX6... • Answered on Dec 25, 2016
0answers
SONY MHC GN 100 D SHOWS EXIT IN DISPLAY AND AUTOMATICALLY SWITCHES OFF
dmb 07 bwb mp card not working
2/22/2014 11:03:49 AM • Sony LBT-ZX6... • Answered on Feb 22, 2014
2answers
Where is my output ic situated
the out put ic is situated inside right side wen the unit front is facing you ,you cant miss it its bolted on a alumium heatsink silver, it has a number stk 412 150 written on it,,,
4/26/2013 2:17:10 PM • Sony LBT-ZX6... • Answered on Apr 26, 2013
tip
Basic HiFi troubleshooting.
First things first. The unit doesn't switch on.
- Is it plugged in?
- Is the fuse blown?
- Does it look like it's suffered damage?
It switches on, but won't play anything / the lights come on, but no sound.
- We'll start at connections. Is your MP3 player/ iPod/ CD player/ record deck plugged in correctly?
- Are the speakers plugged in correctly/ at all?
- Is it in protection mode - this is a pretty standard thing now, where the amplifier tries to deliver more than it's rated current (ie, into a short circuit), and it cuts out. The only way to fix this is to take it to a local hifi shop, who will reset it (there's usually a small fee involved). The unit will be fine after that.
------- There is no bass. ----------
A few causes for this, so there's a few solutions.
- The speakers are out of phase. This is where one speaker is wired normally, one is wired in reverse. The bass from each speaker is "opposite" and would cancel out. To solve this, Make sure the + on the speaker is connected to the + on the amplifier. There's usually a stripe on the cable to help you determine this.
Cause # 2
The eq settings on your ipod/ unit have been messed with.
Set all the equiliser settings to flat, then readjust them to taste.
Cause # 3 (nasty one)
You've blown a woofer. The explanation is this - the speakers have taken in too much power, the bass unit has got too hot and the glue holding the coil in place has melted. Usually, the woofer can't be physically pushed when this happens. To solve this, it's new speaker time. An alternative is to see if you can get a recone kit for said speaker, and try to fix the voicecoil yourself. This isn't recommended to those who are new to the idea.
I hope this helps the reader.
Chris
I have a Sony LBT-ZX6
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealersip.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/13/2010 12:55:38 AM • Sony LBT-ZX6... • Answered on Aug 13, 2010
2answers
I WANT TO HOOKUP MY
Can I have the make and model of the tv so that I can ascertain what inputs it has behind it? The reason for this is coz the surrond system input to be built into the tv reciever otherwise you will just get mono if you plug it into the av jack.
5/21/2010 6:45:57 PM • Sony LBT-ZX6... • Answered on May 21, 2010
Good morning! I wish to plug our television
You may be able to avoid messing with the optical output completely, if the TV has a headphone output, in which case, a phono-3.5mm jack adaptor will sort you out nicely.
If it has to be optical, I expect you can buy adaptors for this aswell, but I'd expect it to be more expensive.
Most local electronics stores will sell these. Radioshack is a good example. Also, you could look around on the internet.
1/25/2010 5:39:57 PM • Sony LBT-ZX6... • Answered on Jan 25, 2010
When you turn on the unit nothin happens but when
when the earphones are plug in the unit you can hear the music cd radio etc . the problem is when i take the head phones out of the unit you dont hear nothing please help.
1/3/2010 8:32:16 PM • Sony LBT-ZX6... • Answered on Jan 03, 2010
0answers
PROTECT
Be the first to answer 8/25/2008 7:43:48 PM • Sony LBT-ZX6... • Posted on Aug 25, 2008Be the first to answer
How do I preset a second AM station on a Sony SRF-M97 Walkman
It looks like the manual knows, and you can have 5 AM station presets and 15 FM. https://www.google.com/search?q=preset+a+second+AM+station+on+a+Sony+SRF-M97+Walkman ..
4/18/2024 5:09:49 AM • Sony Audio... • Answered Yesterday
Sony PS-FL7 direct drive turntable. When start button is pressed it illuminates but turntable won't rotate. All other functions work as they should.
'Direct Drive' appears to mean something different to Sony unless the belt is for another function. https://lptunes.com/products/sony-ps-fl7-ii-ps-fl7-ii-psfl7-ii-turntable-tonearm-belt-replacement Service Manual
Sony PS-FL7 Stereo Turntable System Manual
Vinyl Engine https://www.vinylengine.com > library > sony > ps-fl7 Sony PS-FL7 owners manual, service manuals and schematics are for reference only and the Vinyl Engine bears no responsibility for errors or other inaccuracies. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(56px);"> Rating: 8/10 · ‎ 4 reviews
SONY PS-FL7 service manuals download
NoDevice https://www.nodevice.com > ... > Vinyl Players > SONY SONY PS-FL7 service manual (Vinyl Players) in PDF format will help to repair SONY PS-FL7, find errors and restore the device's functionality. ..
4/6/2024 7:54:41 PM • Sony Audio... • Answered on Apr 06, 2024
My sony icf-cl75ip wont turn on and is making a clicking sound. How can I fix this?
There is not reason this would click and not turn on. If it just clicked, it would likely be caused by interference from another appliance, typically a fridge or freezer. The most likely reason is a relay in the internal power supply. It will need a Sony Service Centre. https://www.sony.com/electronics/support/res/manuals/4154/41545841M.pdf It isn't a recorded known issue. Sony are high quality equipment so it is worth getting it fixed. https://www.google.com/search?q=sony+icf-cl75ip+clicks+and+not+working ..
4/6/2024 2:59:06 AM • Sony Audio... • Answered on Apr 06, 2024
Sony LBT-ZX6 Shelf System Logo
14 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
good morning r ni wish plug our
  • Audio Players & Recorders
