20 Most Recent Dell E171FPb 17" TFT LCD Flat Panel Monitor Questions & Answers
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor. 2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu. 3. Use the down arrow button on your monitor to select "Factory Reset." 4. Push the menu button. 5. Use the down arrow button to select "All Settings." Press the menu button to save changes. 6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
11/30/2014 12:07:30 PM • Dell E171FPb 17"... • Answered on Nov 30, 2014
Dell monster power button flashes green
This would seem to suggest a lack of power from the PC. Check the cable from the graphics adapter (usually blue if VGA) and the connection to the monitor itself.
10/14/2014 11:02:46 AM • Dell E171FPb 17"... • Answered on Oct 14, 2014
Reset factory settings
Monitor has got no icons because it has no memory of itself. All the icons are stored in the hard disk itself which only CPU has. So, I think you can remove then by simply uninstalling the program from control panel> programs and features or simply by deleting the icon by it will not remove the whole software from your hard disk as icons on desktop are only shortcuts.
6/9/2014 6:09:06 AM • Dell E171FPb 17"... • Answered on Jun 09, 2014
3answers
I want to use the Dell E171FPb 17
Hi friend,
You can purchase TV tuner card then you can use as TV. There is not other option for you....
11/21/2013 12:05:53 AM • Dell E171FPb 17"... • Answered on Nov 21, 2013
0answers
I HAVE DONE AS YOU
You will have to open up the monitor next, it can be as simple as blown fuse in the power supply or in the inverter circuits, shorted transistors, bad caps, ect,.
Please see example of failed DELL E series here:
http://s807.photobucket.com/albums/yy352/budm/DELL/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
8/1/2011 9:23:36 PM • Dell E171FPb 17"... • Answered on Aug 01, 2011
Blank white screen blinking when
check the display on some other screen also, if there is no display in other screen the problem is in the cpu, remove the RAM from the slot then insert it again then check
7/29/2011 12:49:02 PM • Dell E171FPb 17"... • Answered on Jul 29, 2011
Having a hard time finding a vga cord for the
This is an industry standard VGA cable. Anything else is something different.(ie not VGA).
6/5/2011 9:00:18 PM • Dell E171FPb 17"... • Answered on Jun 05, 2011
I keep getting an icon, directly in the center of
You have a problem with the buttons on your monitor. The symptoms you describe indicates that the problem is with the menu button acting like it is being constantly pressed. It often caused by debris getting into the button. To troubleshoot, you will need to open the case of the monitor to clean/repair the problem. To do that, you will need a putty knife and seperate the two bezel from the back panel. To help you explain how to open the monitor look at this video http://www.youtube.com/watch?v=9Q6_TgNJvQw Hope this helps you.
1/21/2011 1:25:04 PM • Dell E171FPb 17"... • Answered on Jan 21, 2011
Green light won't come on
Hi Good day!! Try to check the power cable. replace the power cable and then try to turn it on.
11/19/2010 3:48:51 AM • Dell E171FPb 17"... • Answered on Nov 19, 2010
I have hooked up this monitor as a duplicate and
Does it work as a stand alone monitor (single display)?
If not, it may have the problem in the power supply/inverter board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
8/8/2010 7:32:18 PM • Dell E171FPb 17"... • Answered on Aug 08, 2010
Dell E171FPb 17
Same as used for the PC power cord. NEMA5-15P to IEC C13.
8/1/2010 5:31:12 AM • Dell E171FPb 17"... • Answered on Aug 01, 2010
The power went out at my location yesterday and
Reset the factory default: http://support.dell.com/support/edocs/monitors/E171FPB/En/controls.htm#AccessingtheMenu_System
If that doesn't work and it's not under warranty a baseball bat will relieve some stress at least.
6/25/2010 5:39:21 PM • Dell E171FPb 17"... • Answered on Jun 25, 2010
Why won't my Dell E171FPb monitor work? When I
Check the power supply DC filter caps, burnt parts, cold solder joints, etc.
If you are going to DIY repair, please read below and look at my album of failed Dell monitors to get some ideas.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
6/25/2010 3:34:30 PM • Dell E171FPb 17"... • Answered on Jun 25, 2010
17" flat screen not displaying
This message "safe mode press any key" sounds more like the problem is in the PC. You need to try another monitor with this PC, also try the monitor with other PC. Need to narrow down the problem first. Plase post back.
4/9/2010 3:03:19 AM • Dell E171FPb 17"... • Answered on Apr 09, 2010
The monitor will not light up it only flashs when
its possibly because of corrupted BIOS...
one way to clear it out is to reset BIOS into its defaults...
disconnect system from the power supply then,
open the cabinet cover of your CPU and take out the CMOS battery from it...
after a minute put it back in the motherboard...
now start the system...
this will reset the BIOS and the system with default settings...
hope it will clear it out..
if it helps please give a vote...
3/7/2010 12:14:32 PM • Dell E171FPb 17"... • Answered on Mar 07, 2010
Contrast button stuck? driver issue? etc?
It is a hardware problem and needs a replacement. Also try to unpress/release it by tapping lightly on the monitor. If you feel it is a driver problem then go to Start->Control Panel->System->Hardware->Device Manager->Monitor. Remove this monitor and from Action in the Menu select San for New HW. the monitor drivers will be loaded and you can then reboot.
11/8/2009 2:21:54 AM • Dell E171FPb 17"... • Answered on Nov 08, 2009
PICTURE ON MONITOR SCREEN IS SIDEWAYS
Your screen is set to sideways. These the common features for all video cards. You can set it back to default, just go to video control panel of your video card and find Display Rotation.
11/3/2009 3:24:34 AM • Dell E171FPb 17"... • Answered on Nov 03, 2009
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
http://josepino.com/?howto-repair-dell
10/5/2009 12:18:03 AM • Dell E171FPb 17"... • Answered on Oct 05, 2009
Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
61 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
keep getting icon directly in center
  • Computers & Internet
