20 Most Recent
Samsung Galaxy S3 Questions & Answers
Lock password pattern
if you forgot your pattern lock, just give few more tries to continue wrong efforts. at an instant, the OS will report 'attempts exceeded, enter with your gmail'. at this point just enter your email address and in the textbox for password just give value as 'NULL'. this will instantly ask for new pattern lock and you are done!
How to add to rejection list button to my call log
First click your phone icon to bring up the dialer, then click your "menu" icon on the bottum left.. from there you get your call settings.. you can click on call restriction and then create new, and select from the source you want.
Dropped phone in water screen is black
Open it and dry it by using a normal Hair Dryer, for about 1 hour (do not use too hot air, better medium temperature). Than wait for another 2-3 hours and it could be working again.
How do you change the lock if you dont know the password
you have a couple of options, the best is resetting the device to factory settings, or wipe. You will however lose all your data.. But you can log in to verizon wireless via app or web and back your settings/data up if you haven't set up a regular back up already. To do this first have the device powered off.. You're going to use a 3 button combination boot: hold down home, up volume button, and the power button..... you'll see the samsung s3 come up first, followed by the Android logo at which point you will let go.. : Now you will see a small safemode list, using the volume keys scroll down to wipe data/factory reset and select it using the power button: scroll down and select yes: delete all user data, and select with power button again. it will confirm saying its whiping/formatting, and then it ill be complete.. then you can select the first option again with the power key to reboot the device.. It will take a little longer than normal to boot because it is configuring the default settings, and it will boot into the setup phone feature like it was brand new..
