20 Most Recent
Compaq Audio card Sound Card Questions & Answers
Need an audio driver
Windows 7 is an beta version. you cant find drivers for that beta version yet
Good luck to you
Nic
How to install sound driver
Hello, you just can find the driver on the site from compaq and download it. Maybe if there is a search device on the site you just type type your version and which audio card you have....
Free download compaq presairo m2000
Please refer this link and download the audio drivers: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=0&prodSeriesId=433614&prodNameId=500749&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ob-22934-1 Installation Instructions:1. Download the SoftPaq .EXE file to a directory on your hard drive.2. Execute the downloaded file and follow the on-screen instructions.Hope this will help.
My sound on my computer does not work at all
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick ithope this helps
Compaq Evo x86-based pc drivers
What
I could recon from your question is that your audio driver is not
installed in your PC.
Please
be informed that any Driver software depends upon the PC make, Motherboard type
and Operating System. You need to know all the three information's to do get
going.
Please find the Driver software's of your Audio and video inside the
installation disk provided with the PC at the time of purchase. As you have not
mentioned your PC Model Number I am unable to give you the direct download link. However
you can download the same by visiting the website of the company that manufactured
the PC.
Even
here you need to be careful to download the correct software for your PC. You
need to be exact with the PC make and Model number and the OS that you are
using.
To
install just Double clock on the driver setup.exe file and go on clicking
'Next' until you get the 'Finish' option and restart the PC.
I've got hp dx2480 business
Right click my computer then properties then hardware then device manager then see if the sound drivers are installed properly if not installed properly you will see a question mark if disable you will see red X id disable enable the if the driver is marked with yellow question mark then reinstall the driver if the driver is installed and no marks indicated go to the speaker icon in the task bear and open the volume control and see wether mute is enabled if enabled disble them
