20 Most Recent Kyocera FS-1135MFP w/ Document Feeder Questions & Answers
The Error is described in the Service Manual as - "Zero cross signal error The zero cross signal does not reach the control PWB for specified time."
This can be a damaged wire harness between the High Voltage PCB and another board or a defective Power Source PCB. Bad power at the outlet can also cause this.
Move the machine to another location and make sure nothing else is plugged into the same line. If the problem goes away have an electrician check your wiring.
If the problem still occurs have a Service Technician check the machine and replace the bad part.
Kyocera... | Answered on Feb 27, 2015
If this is a color printer, it uses CYMK (Cyan, Magenta, Yellow, blacK) ink cartridges.
MK would refer to the magenta and black cartridges.
Older (one line) displays had limited real estate.
Kyocera Office... | Answered on Nov 17, 2019
If reseating connectors on mainboard do not solve then:
1087 1087 get in to maint.
004 START
Choose the 003 line by touching it and activate it.
Reboot when told to.
Kyocera Office... | Answered on Nov 05, 2019
Probably a broken corona wire. Replace the drum unit.
Kyocera Office... | Answered on Oct 27, 2019
Kyocera FS-1135MFP w/ Document Feeder Logo
16 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Office Equipment & Supplies
Most Popular Question
error c6400 in 1135
  • Office Equipment & Supplies
