20 Most Recent
Kyocera "FS-3140MFP Printer, Copier, Fax & Color Scan 42 ppm" Questions & Answers
C0150 on kyocera
Engine PWB EEPROM Backup Memory Device Problem. EEPROM cannot be written or read\you can try replacing the hdd or the board the eeprom is on
8/6/2014 5:56:47 PM •
Kyocera...
Answered
on Aug 06, 2014
Says jam 12
try taking out feed tray and cleaning the feed rollers with isopropal
acohol, seems to be pick up misfeed
5/9/2014 1:14:22 AM •
Kyocera...
Answered
on May 09, 2014
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
